  • Replies 46
Ive also considered this upgrade but unsure if the benefits are worth it? currently 340kw at wheels thru a gt35r.
house mate went 272 camtechs with precision 6765 and makes over 500 atw but the idle is just so angry its unreal.
256 tomei seem so popular?
There popular because there direct bolt in, retain vct and are big enough for most setups without having to have big compromises when compared to stock cams so good alround performance gain.
  • 4 months later...
Hey guys, I'm in the same position as the op and thought I'd join this thread instead of starting a new one.
It's an rb25 in a 31 making 300kw @ 18psi.
Would a set of 264's be a good choice? This is what I've been leaning towards.
It's a daily but mostly just for fun (don't mind losing a bit of response and torque for some good 4000rpm+ gains).
Obviously I'd get cam gears and valve springs to suit, what company would you go with?
Cheers in advance.
Cheers in advance.
As above - go the Poncams, keep the VCT, forget the cam gears or get an exhaust only.
dont know what turbo you have but a smaller rear housing and upgrade to e flex would be alot more beneficial than cams i think,
Im still not sure if the cams are a good thing for upto 300kw, could possibly create a bit of lag.. no arguments after 4000rpm though, on the streets where revs are usually below 4000rpm the cams might not be such a great thing
Edited by SliverS2
The Tomei Poncams are great value for money..... Mine and Ian's setups are near identical yet i have cams and his are stock (This is NEO so still relevant as a comparison i guess), he makes peak power of 345kw i make peak power of 360kw and the boost curve looks very very similar however i think mine has a touch more midrange. My car idles like its dead stock as the idle is set at 900rpm and there is no lumpiness or anger to be heard. YES i have a HKS exhaust cam gear too.
has anyone done before and after runs with/without cams?
im interested to see the actual difference they make, just upgrading cams
Thats what i was getting at above man, our setups are nearly identical.... The only difference is the cams (actually i have a full exhaust which may hold mine back a little) but it shows the power does increase with no loss of response as far as i can see.
ahh cool! so what about below 4k? before/after?
Mines not that exciting below 4k, yours will react different I reckon BUT I reckon it'll be an awesome addition to your setup :yes:
I run a ported 25, with t04z and 1.05 rear, I dont get my boost on hard till 4800 rpm, im hoping cams, and a .83 rear will bring it hard from 4k. which is what i want. Im not interested in twisting the earth at 3000 revs...
Why do you have a TO4Z and your only making 338rwkW?
Well I bought the whole top end second hand, and I plan to get it on e85 in the next year or 2 when its available and do few more supporting bits for around 380-400. I love the oversize turbo, I get killer economy, its safe in the wet, and i get great top end. When it was bought 1.05 rears were only available. It'll be a bit snappier with a small housing.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
