  • Replies 46
When new, they come covered in a fine coating of a grease / oil to prevent corrosion. You should always wash them thoroughly before installing them.
theres supposed to be a protective coating on them that should be taken off, did anyone do that, i just dropped them in
  • 3 months later...
I'm looking at putting these tomei cams in, iv got a spare head that I'm putting together new springs bit of a port and full clean of everything. I'm trying to find out if the tomei poncam still use vct or it is disconnected? what is the real loss if I disconnect the vct? iv already got a set of hks cam gears as well. I'm aiming for the 400kw range and as low boost as possible. has anyone used the camtech camshafts?
they retain the vct on rb25's, you'd loose alot of low rpm torque,spool etc without it
Edited by SliverS2
I think a kinda good comparison of the low down loss is best experienced driving a ~300kW GT-R vs. a ~300kW GTS-t... you will feel how gutless the GT-R when it is not on song where as the GTS-t with VCT will feel more alive and come onto boost earlier.
It's a misconception many have, thinking longer duration cams bring on boost sooner, I have no idea which keyboard warrior started that rumour but it seems many still think that is the case. I recently had a mate ask me if he should drop in 264 cams into his car to bring on the boost earlier, I honestly wanted to slap him.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
