Well I bought the whole top end second hand, and I plan to get it on e85 in the next year or 2 when its available and do few more supporting bits for around 380-400. I love the oversize turbo, I get killer economy, its safe in the wet, and i get great top end. When it was bought 1.05 rears were only available. It'll be a bit snappier with a small housing.
Wouldn't a 3582R be more suited to your goals? It'll give you a lot more response, more mid range and easily crack out the 380-400kW your chasing on E85.
  • Replies 46
When I bought it all about 5 years ago, it was a fair price, all set up. Now out dated though I know but im not too concerned. If i get boost by 4k ill be happy. even as it is i like it, kinda like a 2 stroke i guess lol
I run a ported 25, with t04z and 1.05 rear, I dont get my boost on hard till 4800 rpm, im hoping cams, and a .83 rear will bring it hard from 4k. which is what i want. Im not interested in twisting the earth at 3000 revs...
Cams won't bring boost on earlier, however cam gears will. Retarding the exhaust cam gear and advance the intake cam you will see more low down.
Just a thought :)
Im also thinking about buying some poncams. Is there just the one "drop in" type for the rb25det (r33 s2)?
I think for the 33 there is just the one type but for 34 there is type A & B
Anyway, if you do get them i purchased off ebay USA and got them delivered for like $600 i think!
FRSport.com is cheaper. I bought mine from the guy on eBay, then my mate purchased a set for $520 delivered from FR. FRSport is so far the cheapest place I have found for any and all aftermarket parts...
Edited by Hanaldo
I can't remember what I paid.... Awesome find though!! I'll be looking them up ;)
Hmmm, perhaps my mate got free shipping because he bought so much from them. Ill find out.
Sounds like it, cus the price I got was 525usd plus 115usd shipping which worked out $600aud I think
Ahh could be the exchange rate as well of course. We bought ours when the aussie dollar was a bit stronger. Mind you, over a $100 difference seems a bit much for just exchange rate. Probably a combination of saved postage and strong exchange rate.
Yeah but the price we got was because it was Make An Offer..... The shipping to Aus is a flat rate no matter what.... So you should be able to get them for $600 with the current AUD I reckon
Not likely. I have cams in a 8.9mm / 265 duration. The Tomei units are straightforward to install without clearance issues.
If you have concerns/issues with noisy lifters, pluck them out while the cams are out. Disassemble and clean.
So i heard that the 8.5mm 256 poncams might require some die grinding inside the head to clear the cam lobes? And possible noisy lifters with them in also. Can anyone who has them confirm?
No chance for 8.5mm ones they are straightdrop in. Its worth dropping in some new valve springs though while your at it.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
