Why is that Alex? Its only dumping 10-15 degrees of timing for 3 seconds or so. Should be interesting to see the flames, lol.
I have to get this barge off the line somehow. Craig sent me this link...
I just love seeing the stuff you come up with and actually get to work. It sure needs a hand to get off the line, maybe an extra litre would help :P
I have to slow my response down low...
No exhaust just poked the dump pipe, yerh foot to the floor.
But I can't understand y I'm stuck at 2200rpms when im trying to stall it up? Shouldn't it let me go beyond?
Not with a 2200 rev stall converter. If you want it to take off hard you went too big with your turbo, now you have to match the stally to the lag you bought yourself. Mine is a 3000 stall converter and it may be for sale soon. I will probably be heading for 3500 stall with 6 lockup clutches instead if 1. (if Kewish can sort me out with one...)
anti lag? you did not tell me of this scott :P
Cihan and I were talking about it, seeing I don't want to go too big with the stall converter and I don't want to spool the turbo with NOS I have very little choice at the moment.
Yes Alex, the 3.5 will help but that isnt getting a plain rebuild, if I ever get the funds I will be shooting for big numbers, too big for a Stagea to handle I believe. ;)
is this wire cut mod only limited to turbo stag's? what about v35s?
I have no idea, I would assume there is something similar in their ecu. Do you have a link to the ECU pinouts? I will have a look if you can find it...
I don't think that the V35/PM35/z33 throttle restriction is based off the same process as the NM35.
I believe its more of a electronic throttle table, that will only allow a specific percentage (or volts to be precise) of throttle opening at X load Y RPM. Not based off the brake signal as far as I can tell. I base this off the fact that I can alter the values in my tuning software. Anyone who has driven both cars will realise the difference.
No pic.
The VQ25dd ecu uses the same plug as the VQ25det so it should be similar but without the pinouts youre flying blind. I have the full M35 electrical book in front of me but I can't read Japanese...
I too can adjust the throttle sensitivity but the restriction is different, have you hooked up the software to see if you get 100%tps at stall? Perhaps its gone now with the re-flash?
yeah ive only got a jap version too
some v35s come with the factory snow/power switch that does the same throttle reduction/increase in sensitivity. i keep mine on snow 99% of the time but it has shown no improvement in economy... still 12.6L/100km
Snow will take off in second usually although I haven't played with the switch much in mine.
each car is different obviously, in my case it still uses first, throttle response appears to be around 10% of normal, revs stay below 2500rpm, and no kickback.
Wat?
So, you put it in snow 99% of the time, but it doesn't improve economy, so in essence your driving around a car that feels like shit for no benefit! I see no point!
The one and only time I use snow is when I'm putting the car up on ramps- because it locks front /rear torque. It will just drive up the ramp easy (obviously you don't have awd...)
Scotty, I haven't done a throttle % map, and it is different now. I have a completely different ecu, even to most of the V35's, as its a Gen 2 Ecu- Runs widebands not narrowbands from factory. But there is just no way there is the NM35 style restriction on our Ecus- stock, there isn't the torque of the turbo motor!
Wat?
i only just calculated the economy after noticing the factory economy meter hadnt dropped....
using the switch is now just to make takeoff alot smoother... as the pedal is way too sensitive on the other settings.
As Scott said its due to the stock stall converter. Should work fine for the stock turbo....well it works great on my setup...
oh ok just realised you had a 3071...hmmm yeah no boost for you LOL
  • 1 year later...
The pedal is way to sensitive....grow a set! This is a V6 not a nissan micra. Get over it or get another car
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
