I was just thinking if you used the dive circuit to complete the circuit once ot goes to either n, r, p it will reset due to tge circuit beind broken with these gear changes. With this in mind how is it with manual shift . Has anyone played with this. Are either drive or manual shift on samewiring circuit?
A quick point on the above questions, I had been thinking about the easiest/best way to achieve this.
One of my early thoughts was to use the ECU wire that sent the CEL signal. It would be sef healing - brake wire mod causes CEL, CEL output resets Brake wire input, CEL extinguishes. Win!
However, the CEL output is a 5V signal whereas the brake wire input requires 12V to reset. :(
So I had a quick scan thru convenient ECU pins & couldn't find anything suitable. Other switches are an earth on so also not suitable (not sure about all listed above).
In the end I connected mine to the reverse lights (already found for reverse camera) so reset every time I go into (or past) reverse gear.
I used the opportunity to install my 'Valet switch' at the same time, so needed a diode to stop reverse lights coming on when activated.
Josh, not sure if there's a diagram as such, but it's Pin 59 on the ECU if you have the pinout PDF.
For what's it's worth, I've knocked up a few pictures. These are very simple circuits, but sometimes a picture is worth more than a heap of text.
1. In it's simplest form. Switch required to clear CEL
2. Better because resets automatically. NB. Can use any temporary source of 12VDC.
3. Optional valet switch (anti-hoon) upgrade. Diode required so reverse lights don't come on when valet switch operated.
And lastly, the ECU diagram (again) for those who don't have it.
ECU_PINOUTS 13_12_10.PDF
Cheers, Leon.
Pin 55. Pink wire with a blue trace.
Thanks Scotty, I should have looked it up properly before posting those pics, lol. Hopefully the diagrams are still helpful to someone - just note my error & cut the right wire :)
No worries Leon.
I know a lot of guys read this thread and have a crack at it themselves, make sure you are cutting the pink/blue wire on the ECU and not the TCU as the gearbox controller is in the passenger kick panel. You will need to remove the glove box to get to the ecu plug.
No worries Leon.
You're right - even though the correct ECU pin number is probably written 2 or 3 times in this thread & many more times in others, someone is bound to get it wrong. As you've hinted, we've already seen an example of a car being sold with a switch that disabled a pink/blue wire on the TCU, lol.
Good thing is pin 59 is probably not populated in our ECU wiring, so that should cause a rethink if anyone blindly follows my drawings. But I'm still ashamed of my gaff :/
Is the wire accessable at the brake pedal?
Maybe Rich, but not sure it's that simple. One of the wires on the brake assembly emits 12V when pedal is pushed (we used this to cancel the cruise control) & I think this is used to light the brake lights (prob via a relay). But when Pin 55 is cut, the brake lights still work, so probably comes off a different control/relay. You can try it if you like - it'd be interesting to know - but since it's quite simple to find & work on at the ECU I'm not sure it's worth the effort.
It has to be cut completely so the ECU doesn't "see" 12V when you put your foot on the brake.
As long as the ECU occasionally sees 12V (approx every 400km) it won't know any different. That is why you need to either a) wire via a switch to restore the connection (put foot on brake, CEL goes out, open switch again), or b) wire to alernative 12V source that comes on during normal driving but won't interfere with you making use of the mod, ie the reverse lights.
The only restriction if following b) above is - you can't launch with full throttle in reverse, lol. I think we can live without that :)
You will need the exhaust done, it is extremely restrictive, especially the dump/cat pos. That will help spool the turbo.
Speaking of which, I may be trying out an anti-lag button for mine to help spool the turbo at stall. I will let you know how it goes. (This should work with the emanage too.)
O really!
Pin 44 is the neutral switch input to the ecu, perhaps that is a good feed to splice in to...
That could work, but I can't find any info as to what that signal is & CBB checking it myself.
The voltages from the switch to the TCM won't work (looked at those before).
Edited by Commsman
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
