Found this. Looks like that signal is the opposite of what we want. Bummer 'cause that would have made it pretty easy.
Edited by Commsman
How old was that post Craig? You gotta get out more...
I gave up on the anti lag, it didn't help much as the stally has been returned to a stock stator, and there is no possibility of it ever making boost. Yours would be a different story. I had plans to test another method to pre spool the turbo, compressed air, but this isn't the car to test that theory on. lol.
I can see mine going rwd manual very soon anyway which gets right around the launch issue. Or perhaps I will drop back to a highflow again for launch boosts, and so the gearbox isn't having quite so hard a time.
Anyway, back on topic, the neutral signal will work one way or another, but if it's 12v then it will be a simple strip and twist, nice and easy for a DIY with pics. I will take some shots when I test this out on the next car. (Damn Leon, you beat me to it. Looks like we will need a relay.)
Relay will probably work as 0V is normally an earth, but sometimes it is just 0V.
But all is not lost for a dead simple solution. Why not use the Start signal on Pin 42? According to my research, that wire has 9-12V when key in start position & 0V otherwise. Sounds perfect, yes?
DIY instructions:
1) Cut wire on Pin55 a few inches from the ECU connector. Strip ECU end & tape up other end.
2) Strip small amount of insulation from wire on Pin42 (leaving wire intact).
3) Solder Pin55 wire (ECU side) onto Pin42 wire & tape up.
Job done :thumbsup:
Testing & pics are all yours Scotty. I'm not moving mine from where it is as works just fine, but the above is certainly an easier solution....if it performs as expected.
  • 3 weeks later...
so has this been tried and tested yet??
DIY instructions:
Job done :thumbsup:
  • Like 1
would i need to install a diod if i went this option
If you don't want to install a 'valet' switch then you don't need a diode when you connect any 12V source, be it from reverse lights, another pin on the ECU or anywhere else.
Ideally a 12V source close to ECU is best. Just need one that is 12V only at times when you don't need full throttle; eg reversing or starting the car.
The only location for reverse lights that I have found is at the rear, so not very convenient (although I already had a spare wire left over from TV install) & the start signal on the ECU is certainly convenient, but Scotty thinks it may not be active long enough to keep the code clear (although I think it should be OK 'cause when mine put out a CEL it would only take a few seconds with the switch thrown & pedal pushed to clear it).
Why don't you give it a go & let us know? If you do the mod you should know in 500km or so. Cutting one wire & joining it to another seems to be the simplest idea we've come up with so far.
Because it will have looked for the brake wire signal & generally spotted a fault in that time.
Mine sometimes goes weeks without throwing the fault; so it can be a bit hit & miss.
Mine takes about 5 seconds to reset. Still worth trying it, as a quick supply of power might be enough to stop the light from coming on, instead of the few seconds to override the light.
One thing I have noticed is I get better fuel consumption with the light on.
You will.....it will go lean.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
