Geez mate, now your testing my memory, lol.
I think initially I had to go digging up top like you, near the high mount stop light. I ran a wire down the passenger side & in behind the side panel where my TV tuner is. I used this to power the reverse camera as well as switch the display input.
Then, more recently, I connected into this same wire for the Pin55 reset, so didn't actually see the reverse light wire as such. I could look at the manual to see what colour it should be, but pretty easy for you to test it by probing it with a pin.
Hey guys I might have a solution that's a bit easier than running wire from rear camera. I only did the brake wire cut today so ill have to wait till the engine light comes on to test it properly.
Months back I installed some LED strips to light the footwells and I powered them from the key barrel ring light which must be triggered by door switch/module. I haven't got my multimeter on me but I'm pretty sure it's a 12v feed as the lights needed that supply, so I was thinking piggy back that wire to the pink/blue brake ecu side and every time I'm chucking the kids in the car/loading groceries/driving with my doors open, that should reset the light automatically. And it's easy to run just across bottom of dash.
So ill wait till warning comes on to see if it will work and will post results. Cheers mates.
Hey Dave, sounds perfect since you've already found that wire.
Of course that will preclude you from launching with the door open for that fully sic Youtube video :w00t:
  • Like 1
Hi all,
Got to test out my setup today, ECL came on in morning and I hooked the wire up to my interior light circuit to see what would happen. Light cleared after about 3 seconds, happy as.
So to anyone wanting a relatively easy way to do this mod and make it automatically reset itself, carry out the following:
Run a wire from the positive side of the ignition key light (ring) - easy to access just pull off a few trims, run it down behind stereo area (straightened coat hanger helps to feed through) across under glovebox to ecu side pink/blue wire.
Job done.
*NOTE: This mod will only work successfully if you occasionally have your car running with the doors open. Also it may still bring the light on over long distance drives, so not perfect but just another way of doing things. Cheers!
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
