Yeh mate, reverse lights is definitely best setup, it's pretty much unavoidable to use reverse every time you drive somewhere, but maybe a lot of guys won't have the car running with doors open...I just always warm it up and leave door open whilst shutting garage, and also have to open door as I park to make sure I'm in far enough, so it'll work good for me!
  • 5 months later...
sorry to revive an old thread, but i will be doing this tomorrow. i will get the 12v feed from the reverse signal wire i used for my reverse camera. seems like a very easy straight forward mod.
I thought the car was just heavy and had heaps of lag, but this should wake it up off the line.
You are on your own with that wiring, hopefully you don't have issues. Let us know how you go. I don't see what's so hard about flicking a switch once a month though...
You should be impressed stalling it up, but it is rarely noticeable on the stock turbo while driving. Once you go highflow turbo it's a requirement imo.
Just make sure you find the engine ECU, not the trans ecu in the kick panel. :P
all done and tested. i noticed it has improved on stall up a bit. i will be getting an exhaust done very soon, im sure that will make a big difference.
anyone know of a good exhaust shop in sydney that knows what their doing with the m35s? i would like a full 3 inch stainless system.
Scott, do you supply full bolt on exhausts or only the dump pipe?
Talk to Theo (WAGON BOY), he has a locally made (Western Sydney) system that is absolutely beautiful. A really nice note, no drone and excellent fab work.
I only do the dump/front pipes, unless the car is here.
  • Like 1
  • 1 year later...
i know this is an old thread but where you have switch to flick to clear code why not use a small momentary push button switch placed somewhere near gear selector so when you want it you just hold down the button launch. release it and everything is normal again no codes .
just an idea
just an idea
Because you will still have to deal with the continual delay in throttle opening any time you use the brake.
Why press a button every time you want to bypass the delay, when you can enjoy life without it, and very occasionally establish the continuity of the circuit and touch the brake pedal for 5 seconds if/when the ECU light comes on.
  • Like 1
  • 2 months later...
Did my inner CV boot today and brake cut mod.
Jaycar $3 microswitch some bending of the feeler and a longer plastic screw to replace the one i took out of the shifter housing.
Edited by malialipali
  • Like 1
Nice one Joe, that should work fine. Let us know how it goes.
From what im reading the ECU will throw a code in a few 100 km if I haven't done it right. I measured and I have 12V over the switch when closed in Park with foot on the brake. Will see in a week or so.
Also if you guys want slightly more sensitive manual shift you can bend the feelers on the microswitches out a little. Did this on a J31 maxima my mum wanted a sportier shift :P .
Hi Folks, an update.
Done about 800km so far - no issues no codes thrown, and I can say with hand on heart that there is definite improvement on take off.
I actually feel confident doing tight handers with on coming traffic knowing I have proper throttle response.
For 3 bucks and about 40 min of my time figuring out the best way to bend the switch feeler etc this was a very worthwhile mod.
Can you write do up a quick sketch to show witing etc and if you can a link to the micro switch you bought.
Sure thing!
Excuse the 90 second iPad finger painting
1. Remove glovebox
2. Locate ECU
3. Unclip the connector from the ECU - pull down the black lever.
4. Unclip the lever by spreading it and pulling away
5. Remove the loom bundle cover (spread it with a flat blade screwdriver)
6. Unravel or skooch up the tape about 5 cm
7. Locate the pink/black trace wire - pin 55 ( the ECU pinout is on the forums here) , put a multimeter on the pin and prod the wire if unsure.
8. Cut and strip the pink/black wire , solder on lengths of wire for the switch. Lengths depend on how you will run it to the shifter box , I followed the existing wiring and drew it behind the deck.
9. Bundle in the new wiring and tape up to existing loom. Reassemble the connector and click it back on the ecu.
10. Slide off the shift knob and lift away the cover, put it aside (no need to unclip wiring)
11. The first plastic screw infront of the shift lever undo and use it to bore out the mounting hole on the microswitch http://www.jaycar.com.au/Electromechanical-Components/Switches/Micro-Switches/SPDT-Miniature-Microswitch/p/SM1038( shows as $4.95 online but I paid 3 bucks )
12. Bend up the feeler , can be done with fingers or long nose pliers - careful not to rip it off the switch.
13. Test fit with the longer plastic screw
14. Solder up as per photo above and diagram. Fix it back in place make sure that the switch closes when in Park.
15. Fire up the car (make sure it works :P) throw a multimeter/test light across the pins and tap the brake - test there is no 12v on the other side by moving the shifter.
Reassemble everything (maybe change your AC filter as summer is coming :) )
My fascia kit is on its way from Amazon US , when I install a new HU I will wrap and bundle the wiring properly , put some hotglue under the switch and over the soldered pins on the switch. For neatness and safety.
Shitty wiring diagram below. I have a CertIV in electronics but honestly couldn't be bothered firing up XCircuit ( 50+ hrs in the office). Ill happily do this for WA members just supply a switch and understand my schedule is hectic and no warranties apply as its a freebie.
  • 2 months later...
So i followed the above and installed the microswitch at the shifter. Only bit i can add to this thread that i had to use spacers below the switch to raise it of the plastic as the switch was hard up against the lever surrounds. A bit of 5mm hose worked well
  • Like 3
So on the way back from SA 100km out of Perth got a Engine Light, I think at that point we drove about 5hrs without having it in park.
First set of lights encountered, in park and about 3 seconds of brake pedal sorted it out.
What I noticed though was when the engine light came on and even when "cleared" the trans shifted weird at low speeds. Wasn't until the car was shut off and back that the shifting sorted it self out , could be coincidence though as Ive just hit 152k km and should flush the trans.
Is it just me or does the wire you cut and stripped look red and blue not pink and black? I'm likely wrong, just something I noticed
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
