  • 1 month later...
As im not one for cutting up factory wires and get plug in parts. It has come time to bite the bullet and do the brake cut mod. I am looking at doing it another way than what has been discussed previously. As my car has cruise control im looking at finding the wires associated with the on off switch on steering wheel cutting and terminating wire on the body side of ecu and connecting ecu wire to whichever cruise control wire becomes active when switch is turned on. If that does not work i have a switch i can solder in and run it to glove box
Just did it with a normal switch. On thinking about cruise control on off switch i would be limited to 30% throttle for the whole duration if i used the cruise control on a long drive may have been good for fuel consumption but i will never know
So have you done a test launch yet?
Watched the mighty car mods episode 12 of the double unicorn build. It touched base about the throttle restriction due to the atessa system in the wc's. I wonder if it's the same for us as we use that system? It was along the lines of g sensor and voltage sending info to the atessa which would tell the ecu how much power to send to the tranny etc..
  • 1 month later...
There may be a big smile on your face. There definitely was on mine. Takes a while to stall up but it does happen.
Till about 3 weeks ago I didn't bother stalling up for more than 1-2 seconds , have been and still am very happy with general pedal response coming of the brakes. However bout 3 weeks ago I was waiting at a very tricky roundabout and stalled up for longer with foot flat ...... damn!! the grin I had! back end lost traction front scrambled for grip and the darn thing shot off like never before.
Car is stock except constant high boost, brake mod and trans cooler. This of course has resulted in a special kitty being formed for serious mods to happen. It is (to me anyway) exceptional how well these things get off the line.
Yep well worth the back cramps leaning in to the firewall, cutting and connecting the wires.
It's surprising how lazy Nissan tuned this car given the weight of the thing.
At least they gave it decent factory boost.
Even my wife loves it more now after she drove it through the forests of Durras lakes with the brake cut switched off.
Good little spot here for a switch, in the passenger side utility compartment.
Towards the back of the compartment , there's plenty of clearance behind for the mech.
Very easy piece of trim to remove, 2 screws then jiggle out.
Better than glovebox I think , less chance of getting broken.
I think my tyres are wearing out quicker all a sudden ;)
  • 11 months later...
Dragging an old topic up.
FYI, I have an AR-X that is 100% standard and I can get it to stall up on the brake to 3200rpm no problems, to the point that the rears start to spin. To my knowledge the mod hasn't been done as there are no CEL codes.
Not too sure on how much boost its making but it leaves hard off the brake with no hesitation.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
