So ive decided too take my R32 off road and turn it into a Drifter ile start by listing the current mods then mods im going too add, if you have any advice on parts please comment :yes:
Current Mods:
Engine:
RB25 S2
Yellow Jacket Coil Packs
FMIC
Microtech LT12s
HKS Electronic boost controller
3" Exhaust
Stock Turbo
Suspension and Steering:
Tein Super Street Suspension
Driveline:
R32 Gearbox
Nismo 2-Way Locker
Interior:
Stock
Future Mods:
Engine:
HyperGear G3
deatschwerks 1000cc Injectors
deatschwerks 300LT/H Fuel Pump
E85 :woot:
Power steering cooler kit
Engine Oil Cooler Kit
Driftworks Geomaster - Offset Rack Spacers
Steering angle spacers
Stainless steering bush
Driftworks Front & Rear Adjustable Lower Arms }
Driftworks Camber Arms }
Driftworks Toe rods } Might use gktech products instead
Driftworks Traction Rods }
Driftworks Tension Rods }
Tein Tie Rods & Tie Rod Ends
25mm hub centric spacers
Driveline:
Expect the r32 box too break so ile put a 33 one in when it does
Diff should survive along time
Interior:
Remove whole interior apart from dash
Racing Seats
Harness
Rollcage
Hydraulic handbrake
Mixed gauges
Exterior:
Paintjob
Bodykit
Rims
So im looking around 10-15k on a guess for all this, if theres things i dont need or extra things i need, please let me know, this build will be starting very soon! stay tuned.
I heard a s13 cradle will allow better lock which always help when sideways also a gtr diff it's a cheap good upgrade 15 g is a fair wack to build a drifter
Just read nismo 2 way my bad
Edited by Bsa
I was also reading on a driftworks forum about the cradles, but a few people said its only the s14 and s15 cradles that will allow better lock and haha yeah i know it seems alot but that seems too be the cheapest options with the most amount of mods if i could id spend 20+ but thats not really an option at the moment, also if anyone knows anyone who can make roll cages in queensland at a decent price, i was quoted 3,500, seems abit pricey, might just buy a tig and do it myself, just dont have a bender lol
Edited by 51NNA
Yah 3500 is a bit steep for a cage. I got quoted in sydney here from pro fab 2200 and thats a full 6 point cage with side impact bars accross the doors :) Good luck with the build im also in the middle of a 32 build for drift and circuit work :)
The Cage in our R32, was from motorsport solutions Australia a few years ago, fully cams approved 6 point for under 2k. there is a thread about him here http://www.excelrally.com.au/forum/showthread.php?t=587, old thread though i'm not even sure if theyre still open but you can send me a PM for his number if you would like.
Cheers
Thanks for the info mate, but ive decided im going too build my own, i need the experience because theres also a KE30 rolla in the works as a drag car, so id have too build a cage for that too.
UPDATE:
Not going with the HyperGear Turbo anymore, going with a GTX30/76 .82, for 200$ more a trusted brand name is a better option lol
Edited by 51NNA
garrett_gtx307x_sm.jpg Garrett GTX3076R RB25DET T3 Bolt-on Turbocharger 550hp, Dual Ball Bearing Kit
- Actuator Boost (Min) 16psi
- Ceramic Coating - None - $2,329.00AUD fuel_upgrade_kit_ts_6cyl_sm.gif Fuel System Upgrade Kit Stage 3 - Nissan R33 GTST - RB25DET (834HP)
- Injector Impedence Low $1,220.00AUD dc_dcsl-12-0162_sm.gif Davies Craig Electric 12inch 12V Thermofan - Fan Only $145.00AUD iridium_6cyl_sm.gif NGK Spark Plug, Nissan Skyline R33 RB25DET Iridium Plugs Set of 6 $116.00AUD haltech_platinum_2000-trans_sm.gif Haltech PS2000 Engine Management System - Nissan RB Series Engines
- Air Temp Sensor + Connector - none -
- Coolant Temp Sensor + Connector - none -
- MAP Sensor + Connector - none -
- Throttle Position Sensor + Conn - none - $2,345.00AUD walbro_400lph_tweakit_kit_sm.jpg Walbro 800HP+ 400LPH In-tank EFI Fuel Pump - Tweakit Universal Kit $195.00AUD
Parts im getting so far lol and that was the cheap part :unsure:
Nice will be good to see some more gtx results on a rb25 although the rear housing worries me as they have given people alot of trouble in the past. Any particular reason why you decided to go with thermos rather sticking with the stock clutch fan setup?
Oh? I didnt know about the rear housing issues? and Reason for the thermo is because my intercooler piping hits the fan and the bonnet so i had too trim it, which made it unbalanced and yeah... plus the stock shroud doesnt fit back on lol, so its really my only option.
I got a 32 skid hack aswell IMO power isn't everything it helps but if I were u I'd concentrate more on the sus set up to begin with. Solid steering bush is an easy yet effective mod , cheap too makes the steering feel way more responsive. Caster/tension rods are a wiked mod too make the car self steer way better on transitions. And finally camber! I find it makes my car snap harder on the transitions. I also run massive track all round achieved by spacers on the rear and lengthened and re mounted lca at the front. This I find makes the car feel more at home when sliding off pwr and look boss. On the lock front I moved the rack froward on the crossmember rather than run offset spaces and just ground down the factory lock bumps on the knuckles this may not look like a massive gain in lock but the result was amassing to drive.
Yeah, your 100% correct. Im going to just focus on the steering and get a retune and see how it feel's on the track. It's already got a nismo 2 way and its a non HICAS model. :yes:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
