hey guys,
easy question this time, looking for double sided tape that will actually hold something on (bit of body trim has lifted, gunna refit) unlike the crap you buy from supercheap.
would like it super sticky, thin and not to expensive.
buying online is fine or somewhere in/around newcastle
Jarrad
https://www.sau.com.au/forums/topic/397980-double-sided-tape-that-sticks/
As above 3M double sided tape, has red backing paper. If you want something that isn't going to move pretty much ever try out 3M's VHB 4991 double sided tape (i believe it's what is used to hold the go-pro camera stands etc to cars/boats etc...)
I don't think you can simply get this one from bunnings, but i may be wrong as i get it directly from 3M
where's the cheapest place to get it though, ebay, bunnings or online somewhere, anyone got some shop prices for comparison to online?
Its a roll of tape :P Just pay what it costs ya tight prick LOL!! :) :)
So i dont start a new topic.. can anyone tell me if this stuff works on dash boards? EG under the steering column for turbo timers/ gauge control units?
Iv tried so many things, command strips, double sided tape.. HOT GLUE! (this worked the best)
But eventually everything has fallen off. I even cleaned the area with thinners to try get the dash oils away. One way or another it falls off in the heat.
dash boards are always going to be likely to loose the grip of the tape if they are constantly in the sun . thinners are a bit much to clean your dash lol harsh.. try wax and grease remover , thatll be a little more friendly , you wouldnt want any cloth streaks in your dash from thinners :P .
Tried sikaflex? http://www.sika.com....to_products.htm
it's what they use at the factory when they need to hold on bodyparts/trim without screws/bolts/stupid plastic lugs etc.
**edit: good luck EVER getting it off though
Edited by Gibbon138
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
