got your email man :) Thanks.
Matty, The RH9 car I'm talking about was an R32. When i saw it it was about 10-12 years ago. It's probably changed hands/plates/dead. Short stocky/chubby dude owned it. Can't remember his name though.
  • Replies 110
  On 22/04/2012 at 6:22 AM, God_speed said:
I got contacted by superjet760 earlier in the month regarding some parts; I believe he still owns the R32 that is running 8's, number plate is RH9GTR. He's still around these parts
The (other) GTR with plates just RH9 was that Midnight Purple II R34, right?
Can vouch for Michael's R33, it's fat
Paul (superjet760) still owns the [RH9GTR] beast - it is for sale, but hasn't been sold yet.
  On 21/04/2012 at 7:02 AM, luke GTR said:
i thought he wanted cars, not boats.
:P
jokes, jokes.
looks nice mate
:P
jokes, jokes.
looks nice mate
Why dont you bring your dinghy and we can both go sailing. :D
deja vu?
mmmm sailing!
Well peeps... first shoot has just wrapped up. GTRSEAN got his car ready with a few hours notice and althought I can't post anything up here just let me say the results are Amazingly Jizz Worthy. :D Looking forward to the next shoot already.
I'd just like to say a big thank you before I depart this country for a few months haha... :( for taking the time to photograph the beast. :D
Looking forward to the pics, even though I've seen a couple ;)
Thanks Terry, we did talk about your N1 and Matt's Nur getting some photo sexy times too ;D
I won't be able to post any more from the set until after it's all published but here's an unfinished shot from the set. Just to show you guys what we're talking about. :)
lol. Special location. RAAF base Richmond yeah?
Love the mountains in the distance. Spent some time there but never saw it as good looking as that.
Well done Matt, and Sean.
Yeah guys, taken at the RAAF base looking across the runways towards one of the best sunsets I've seen all year. I've updated that pic I posted with the final version of that shot now. Like I said before I can't post any more other than the teaser until after it's all published. :(
I don't think it has a pearl, it's just polished like a mofo and the colours from the sky were coming out in the paint.
It won't let me edit... so you secretly get two. That first pic isn't 100% complete as it was posted anyway so I don't feel bad :P Here's the official teaser.
Edited by MaTBoY
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
