Yeah I would love to see how Ant's yellow paint comes up from behind Matt's camera.
Mate are you going to leave the eyelids on do you reckon? I took mine off, they were good quality ABS plastic though
It will get behind Matt's camera I'm sure one day, probably when the cars a little more finished though at this stage...
The eye lids, tbh it has never bought enough attention to me to really have a good think about it (strange, as I believe the attention to detail on my car is beyond obsession, hence why the car is back at the painters again working on the bonnet ha)... Im not even 100% certain what they are, they look like nismo ones, and I like the style of them far greater than other r34 eyelids I have seen as they aren't very aggressive... But im not really privvy to what's out there either in the way of them, just not something i have really looked into.. So yea at the moment they are staying, if they didn't come with the car, I highly doubt I would have bought some, but looking at them doesnt make me what to take them off... Abit weird as there not really my Thing, but oh well... Was thinking the same with the te37sl stickers I have too.... Tough decisions haha
  • Replies 110
Its pretty nice looking but If yu scroll back a page or two you'll see its to similar to the last car shot. Any specs? Pretty sure the 99% of thread will want to know whats In It.
Thanks Matt,
Pretty much the i bought the car as a standard Vspec and then added a few bolt on mods,
The specs are as follows:
Aragusto Coilovers
TE37SL 19x10.5
Nismo Skirts and rear aprons
Tinted front and rear indicators
Yokohama 19 x 275 rubber
Tomei 260 Pon Cams
Trust Cam Gears
Nismo Fuel Pump
Sard RZ fuel reg
Split fire coil packs
Cusco Brake stopper
Haltech Platnium Pro Computer tuned to 260 at all fours for now
N1 Water pump
120mm Cooler
3.5 inch custom Exhaust and front pipes
ORC Twin Plate Carbon Pro Clutch
Theres a few other things I left out probably.
Other things to be installed on the car which I have been lazy to get done but are
sitting on my shelf
Garret 2860-5s
Tomei Dump Pipes
Sard 800cc injectors
HKS Kansai Brace
and re tune
The car runs on royal purple and motul fluids and gets serviced every 3000km
and never leaves the garage if its raining or windy lol too paranoid of a branch falling on it,
if anyone wants to know anything more feel free to PM me =)
Cheers
Garth
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
