Yeah I would love to see how Ant's yellow paint comes up from behind Matt's camera.
Mate are you going to leave the eyelids on do you reckon? I took mine off, they were good quality ABS plastic though
It will get behind Matt's camera I'm sure one day, probably when the cars a little more finished though at this stage...
The eye lids, tbh it has never bought enough attention to me to really have a good think about it (strange, as I believe the attention to detail on my car is beyond obsession, hence why the car is back at the painters again working on the bonnet ha)... Im not even 100% certain what they are, they look like nismo ones, and I like the style of them far greater than other r34 eyelids I have seen as they aren't very aggressive... But im not really privvy to what's out there either in the way of them, just not something i have really looked into.. So yea at the moment they are staying, if they didn't come with the car, I highly doubt I would have bought some, but looking at them doesnt make me what to take them off... Abit weird as there not really my Thing, but oh well... Was thinking the same with the te37sl stickers I have too.... Tough decisions haha
  • Replies 110
Its pretty nice looking but If yu scroll back a page or two you'll see its to similar to the last car shot. Any specs? Pretty sure the 99% of thread will want to know whats In It.
Thanks Matt,
Pretty much the i bought the car as a standard Vspec and then added a few bolt on mods,
The specs are as follows:
Aragusto Coilovers
TE37SL 19x10.5
Nismo Skirts and rear aprons
Tinted front and rear indicators
Yokohama 19 x 275 rubber
Tomei 260 Pon Cams
Trust Cam Gears
Nismo Fuel Pump
Sard RZ fuel reg
Split fire coil packs
Cusco Brake stopper
Haltech Platnium Pro Computer tuned to 260 at all fours for now
N1 Water pump
120mm Cooler
3.5 inch custom Exhaust and front pipes
ORC Twin Plate Carbon Pro Clutch
Theres a few other things I left out probably.
Other things to be installed on the car which I have been lazy to get done but are
sitting on my shelf
Garret 2860-5s
Tomei Dump Pipes
Sard 800cc injectors
HKS Kansai Brace
and re tune
The car runs on royal purple and motul fluids and gets serviced every 3000km
and never leaves the garage if its raining or windy lol too paranoid of a branch falling on it,
if anyone wants to know anything more feel free to PM me =)
Cheers
Garth
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
