Brought some bride material, finished the car and have a few meters left overs.
great stuff to fresh up your old beaten up falling apart interior trims.
it comes in continuous length with 1.6 meters wide.
the bride letters goes length way and gradation goes width way. along there also have full black area with 'bride' on them, quite hard to see on pic.
material sells in 0.7 meters.
Only $40 dollars a section!!!!!!!!!!!!!
each meter is 0.7x1.6 which is 1.12 square meters. 1 meters is enough to cover 2 doors and some left overs. 2 lengths is enough to cover the whole interior including all the console area and back seats! great stuff!
Doncaster east Melbourne.
call or text 0433289998
i am interested if you have enough left to do full interior, let me know cost including shipping to glenbrook nsw 2773. can pm if you like thanks
jeremy
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
