I am trying to adjust the timing on my 97 C34 with the s2 RB25DET in it.
I was having detonation so I checked the timing and it was on the crank mark furthest to the right when looking at it from the front. Came like this from japan, ran great, quik and smooth with a bit of det only on WOT runs. I loosened the CAS and set it to the 4th mark from the left(15 deg). Car hesitates under medium to heavy throttle, no det sounds and also hesitates when cold at parking lot speeds.
I am still unsure which tps plug to unplug, when I unplug the brown lower one, the car just dies. So I set it with the grey upper plug unplugged, but I hear thats the kickdown, so its probly made no difference.
So which plug do I use to get base idle?
https://www.sau.com.au/forums/topic/398007-having-trouble-with-cas-timing/
I use the loop wire hanging out of the loom at the rear of the rocker cover,I don`t disconnect anything and also set the timing at 15 degrees, works fine for me, depends on what type of timing light that you have, what fuel are you using, what boost , all variables that can effect timing/performance etc
Ok, I did try setting it without unplugging things, but the computer advances it or something and the marks go away. I downloaded the r33 and r34 fsm's and they both say unplug the tps brown plug, but my car dies with it unplugged, but my car has had issues with the idle swinging around when I first start it, but it always stays running. I figure I'm gunna give the Idle air valve a good cleaning and try unplugging the tps again.
I'll be running 94 octane which is close to 98 RON, but I wanna be safe for 91 incase I venture down to the states.
You should have 3 plugs in front of your inlet manifold disconnect the top black one then use a good timing light and run it off the white wire at the back of your rocker covers. Found a little shortcut by putting the timing light half on the wire you can get a accurate base timing readout instead of running it off cylinder 1.
Ok, cleaned the Idle control valve, got some good chunkies out of there, now I can unplug the tps without it stalling and set the timing, so its set properly now at 15. Hopefully solves my detonation issues.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
