Ok I was contacted a while ago by this guy Gary. He has a GTS2 which he has owned since new, thats right it's a genuine 1 owner but unfortunatly he has lost the the use of his legs. So in turn he can't drive his beloved R31 anymore & doesn't want to wreck it by installing the controls he needs to drive (plus he has to have somewhere to put his wheelchair).
Anyway here's what I know about the car & please contact Gary on the numbers below.
Make/Model: Nissan R31 GTS2
Year:1989
Kilometers: Don't know
Transmission type: Auto
Engine: RB30e
Colour: Red
Modifications: Alpine DVD player
Roadworthy Certificate: Not to sure, contact seller
Accident History: Not to sure, contact seller
Asking Price: $9000
Contact Details: Gary 0414 820 483 or 3886 1398
Other Comments:
It is with much sadness that I reluctantly offer for sale my 1989 GTS 2
Skyline.
This is a Photo of the car,
Red
with white wheels
1989 GTS 2
1 Owner (me)
3 litre Factory
worked
Recently Powdercoated White Wheels
New Steering Rack
Alpine DVD
player
She is still in BEAUTIFUL condition
This car has only been
lovingly driven by myself and my wife and has not been thrashed or hammered in
any way.
It has always been garaged and regularly serviced but has only been
driven occasionally for the past year as I am no longer able to drive it.
I
would like to get a fair price for her and would like to offer her for
$9000.00
If you have any further questions, please contact me on the
numbers below.
My contact number is 0414 820 483 or 3886 1398
Gary
Thanks guys
Carl
Closed.
Per the rules:
6. No posting on behalf of others! - If your mates want to advertise their parts here on SAU, tell them to register - If you dont own it, dont post it for sale.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
