The wife has once again put her Stagea RS4 automatic in Park before it came to a complete standstill and jammed the park pawl in. Normally a bit of rocking of the car, to and fro, releases it, but this time she decided brute force on the selector lever was the answer and something under the car, in the linkage, has bent. I can see the cable is moving inside the car, above the tunnel, but underneath? Who knows? One can feel the friction of something moving, but not freely. the lever will select all gear positions, but the parking pawl remains resolutely in place... I suspect a bent cable or lever, but could do with a diagram or photo of the linkage at the `box end. so I know what I am letting myself in for tomorrow, as I can't get it into the workshop, and it will have to be done outside, on my back. I had to tow it up the drive with the back end on a trolley jack. Luckily this occurred at the gate, and not out in the sticks which is her route back from work. BLOODY women....frown.gif My FAST set up is not on my current PC, and I am not 100% sure it even had the RS4 Stagea on it anyway. Can anyone help please? Thanks.
https://www.sau.com.au/forums/topic/398012-rs4-auto-box-photos-wanted-please/
I think this is the one:
http://www.makcotran...pdf/RE4R01A.pdf
Thanks for the pdf file! That's certainly useful, but still could do with a photo of a box out of the car showing the linkage as fitted. Much appreciated KiwiRS4T, thanks very much mate :)
Sorted now, the cable where it is anchored by the selctor lever on the `box had split. Pushing the lever forward worked fine, pulling it back, (especially when forced, if stuck in park....) resulted in the outer moving, and the inner staying still. Used cable on its way, thanks gentlemen!
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
