Genuine WALBRO 400LPH Fuel Pump
- Most popular in-tank performance fuel pump on the market today
- 400LPH supporting 750+HP applications
- Genuine WALBRO – manufactured in USA by TI Automotive (box may be generic TI)
- Comes with 2x free strainers and kit
- Most popular upgrade across the Nissan range; RB's, SR's, CA's ect.
$190 $180 incl. Delivery >> SAU Special
E85 compatible version now in stock - 460LPH - $220 incl. Delivery
* This is an Australian delivered product with a national warranty.
whats the eta to sydney brookvale 2100 and will this be a direct fit into a 1999 nissan stagea 260rs?
Hi,
I can have one at your doorstep by Monday.
In terms of installation it is a relatively easy install across the Nissan range - very popular choice of in-tank pump!
One thing to note is you will need to wire a separate power supply and relay because Nissan's don't run a constant 12V at idle which the pump may not like.
I have double checked this with a full-time tuner in Melbourne that installed plenty of these.
- Brendan
Hi,
- Brendan
thanks
  • 4 months later...
Are these the e85 compatible pumps?
Guys use them on e85 however we will be getting delivery of the e85 specific ones from Walbro within the next 2-3 weeks!
- Brendan
  • 3 weeks later...
Those Walbro E85 pumps are in! 460LPH comes with strainer and terminal - $260 incl. delivery
Hurry as stock is super limited - 2 left
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
