If your rotors are getting close to minimum thickness, get new rotors regardless of whether they are standard, dimpled or slotted.
Do you have Vernier calipers or a micrometer?
Have you looked up the minimum thickness spec?
Yeh I will do that before I decide. Thanks mate
I got the broken brake line made again, but sadly it still wont fit... The end bit is protruding out of the bolt and it wont seal properly.
This is the reason why I was looking for a factory part. :|
Edited by R1maniac
The bends are ok. I can still get it in, but it doesnt go into threaded hole properly.
The end of the pipe needs to be flat and tapered inwards. (The fluid was coming out where the red arrow is)
I've flattened the ends now, will see if it fits..
can you guys tell me where I can get original ones of these from the internet?
Cheers
They're unlikely to be available except maybe from Nissan spares, probably with a few weeks wait to get them from Japan.
Worst case, trailer the car to the brake shop so they can make it fit.
The bit that the brake shop made is causing the issue. I work full time and i dont have time to go up and down everyday, so i guess its best option to leave the car with the brake shop guys to make it fit.
Wouldnt wanna wait weeks to get the part shipped from Japan
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
