Midnight Purple - 1995 R33 GTR V-Spec
This car is perfectly built to be an above average modified street GTR that you can take to the club level circuit days on weekends reliably and without issues. Or really have some awesome fun in the hills. The suspension setup on the car is really something else, if you are interested and come check it out you’ll see what I mean when test driving.
Don't buy other overpriced R33 GTRs with a stock motors and bolt-on's - spend a few more $$$ and grab one with a proven reliable motor & setup and save yourself the rebuild bills down the track
All modifications have been carried out in house at Racepace Motorsport and the car has been serviced every 5,000kms or less.
Motor:
R33 RB26 rebuild by Racepace Motorsport. Includes forged pistons, forged rods & R33 GTR crank.
Head was fully rebuild, ported & tidied to Racepace custom specifications. Enlarged oil returns & restrictors - track ready/safe motor.
PowerFC Pro Edition (comes with ignition cut & launch rev limiter).
Garrett -5 Turbos, Tomei dumps into Apexi front pipe & 3” exhaust cat back. (10,000km old turbo’s).
9.5 LTR Racepace Sump - Winged/Gated (8,000km old).
GReddy FMIC
Large Oil cooler with Filter relocation.
Sard 700cc Injectors (10,000km old).
Nismo AFM’s with stock airbox & K&N Filter (10,000km old).
OEM Coil packs.
Nismo intank fuel pump.
Custom catch can & washer bottle setup
Suspension/Brakes:
Racepace Tein RS coilovers – Custom spec, re-valved and configured. Believe spring rates are 8 front & 6 rear.
Racepace Modified stock upper arms.
D2 Racing 356mm Brake kit upgrade. Ferrodo DS2500 pads Front/Rear. ADR Brake lines. Cusco Brake Master stopper.
Drivetrain:
Nismo Coppermix Twin Plate clutch
Nismo 1.5 GT-Pro LSD – Rear (1,000km old, freshly run-in).
Nismo 1.5 LSD for GTR – Front (5,000km old).
Rebuild & Modified 4WD Transfer case – Extra front drive, excellent improvement out of corners over standard.
Cosmetic:
Series 3 Front lip
ARC Air deflector panel
Nismo Dash & centre gauge cluster.
Full motorised Ganador mirrors
Brand New Sparco suede wheel
Interior is overall in very good condition. No tears in sets etc.
Makes ~360rwkw @ 19psi on a conservative track tune. If you wanted more power just put a 3.5” exhaust on and more boost.
Or E85 and see 400rwkw like everyone else does.
There is probably other stuff I've forgotten to list in the above. I'll update as i remember bits & pieces.
Price: $33,000 - 6 months registration, RWC upon sale and has just been serviced.
Price is negotiable if you do not want some of the listed spares below.
Spares & extras: – These are included in purchase price, over $4,000 in extras
AutoSelect Full Carbon insert dash, centre console, door insert/handbrake boot
R33 Series 3 Door trims.
Set of Xenon headlights (average condition).
Set of R33 GTR wheels with Hoosier Drag Radials 275/17, hardly used, 6 months old and Stored correctly.
Carbon Fibre rear diffuser.
New Sparco Harness.
Mines Rear wing carbon insert (needs repair).
HKS EVC 5
Overall body condition is excellent. Front end is in excellent condition.
Stickers will also be removed before sale, body come up exactly how it was pictured below prior
Upon sale car will have R34 GTR wheels with tyres fitted.
Wedsport SA90s fitted with 285/30/18 AD08s, will not be sold with the car at listed price. Price to be negotiated if buyer is interested.
Enquiries via PM or Forum Email
post-709-0-73123400-1334741085_thumb.jpg post-709-0-56036100-1334741086_thumb.jpg post-709-0-43613900-1334741087_thumb.jpg
Thanks.
Need money for other ventures at the moment.
If I didn't I'd just keep it given the amount of money I've put into it in the last 6 months with new diffs/sump/brakes etc.
GTR's are not full time AWD. Quoting rwkw is perfectly normal, most results in the RB26 dyno thread are done in this fashion.
If you want to know more about the GTR ATTESA system, and how little difference it makes to dyno results - use the search.
  • 3 weeks later...
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
