Hey guys, i have 2 C33's and 1 A31 getting parted out, they will be available in about 2 weeks, but just drumming up some interest now for anyone who wants to get in early. I will have confirmation on brands and specs of some of the products that are a little vague atm as soon as they get here. I can do these as packages, just let me know exactly what you're chasing and i'll price you up a better price based on how much you grab at one time!
Located neat Mitcham in SA, can post anywhere in Aus!
R33 RB25 Engine - $1900
with Tomei Poncams
(without injectors/ecu/plennum/turbo)
R33 RB25 Engine - $1400
(without injectors/ecu/turbo)
RB25 Manual Gearbox - $1100
Clutches:
OS Twin Plate Clutch (good condition) - $800
Exedy Super Single - $650
Turbo:
HKS GT2540 Turbo (with return line and elbows etc) - $1100
HKS GT2535 Turbo (with return line and elbows etc) - $1000
Garrett T04E (have matching manifold and gate to match, gate specs TBA) - $800
Accessories:
HKS Exhaust Manifold (Stainless steel) - $600
Oil Cooler with Relocation kit - $600
Z32 AFM - $150
Infiniti 90mm Throttle - $300
Nismo 555cc Injectors - $550
2 Layer Radiator - $200
Aluminium Radiator -$200
R32 GTR Intercooler with Piping - $400
Front mount inercooler with Piping - $250
Greddy Plennum - $900
Oil Catch Can Tank - $100
Aftermarket Front Pipe - $100
Lightened Flywheel - $200
GTR fuel pump - $90
Ecu:
HKS FconV Pro Silver - $400
Apexi Power FC w/ Controller - $1100
Boost controllers:
Blitz SBC-ID - $400
Trust Profec B2 - $350
If there's any cool/rare stuff on the laurel shells I'd be interested.
hey mate, there's a bunch of laurel shit coming back, there will be a thread up about that soon, but not 100% sure what's left on it after i got my mate to take a bunch of stuff off before it was sent over for my laurel over there.
awesome, i'm chasing anything thats hard to get over here, front lip, centre console with cupholders,weathershields anything little like that.
Venetians? hahaa
haha i have weathershields on my C33 streeter in Japan, but not sure if i have any coming back, cupholders ill check.
with Tomei Poncams
Clutches:
Turbo:
Accessories:
Z32 AFM - $150
GTR fuel pump - $90
Ecu:
Boost controllers:
Blitz SBC-ID - $400
I was wondering if you had a throttle body to suit my 97 R33 gtst S2?
Do I see r33 gtst coilovers
not sure where dude? the ones in the pic are S14 as you can see by the 3 stud pattern and camber tops, not sure if you mean something else?
Hi there. With regards to the OS clutch, is it a push or pull type? I have a 2WD R33 with a push type clutch and am needing a multiple plate unit due to the power output. Can you please include some pics with the plate wear, heat spots & any other issues. Also - any idea on postage to QLD mid coast?
  • 2 months later...
Clutches:
Turbo:
Accessories:
Oil Cooler with Relocation kit - $500
Z32 AFM - $150
TRUST Intercooler core (rough condition, but works fine) - $200
GTR fuel pump - $90
Ecu:
Apexi Power FC - $1100
Boost controllers:
Blitz SBC-ID - $400
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
