Well after the flash flooding in my area last night and the sheer amount of water everywhere the stagea has gone nuts.
Abs warning lights a/t check 4wd warning light rpm and most of the dash is out. Can't control wipers blinkers headlights. Engine appears to run fine.
Gearbox started banging through gears. Obviously it appears there is some junction box for many sensors that has been water logged. Question is where the hell is it so I can dry it and seal it?
I have left the car running in the garage to see if the heat would get rid of the water from where ever it is but no luck.
Stuck without car :(
https://www.sau.com.au/forums/topic/398111-rain-has-killed-my-m35/
It could be water related, but most random electrical are related to dying batteries in the M35.
Even with a full 12.7 volts charging into mine; when the battery was dying, it was throwing all sorts of random airbag & CEL alarms. Even though it started fine and ran fine this was an issue. Replaced battery; no more issues.
Check the battery under load when starting, this is the only time you can really see how they're performing.
AT and engine ECU are in the passengers footwell, you'll need to get the glove box out. BCM (body control module) I'm not quite sure, but I think its somewhere behind the gear shifter / arm rest. Someone else will firm that one up.
Was your car submerged?
Make sure you disconnect the battery before mucking around.
I just drove through some puddles...
Everything is effected from blinkers dash headlights turn on and off i cant control anything. basically nothing seems to be working or is intermittent. It wasnt anything i would call ridiculous. It just rained heavy and drove through some deepish puddles.
As someone said on that other forum that the stagea uses a data bus to send signals so if that gets water in it. Then you have to wait for it to dry out. Im not going to go pulling the car apart looking for something i dont even know what it looks like that will just piss me off more.
You do know that is not the same car in the link, yeah? Its an Infiniti M35- a sedan sold in the US.
Same sort of basic architecture, but it still is a different car.
http://www.netcarshow.com/infiniti/2006-m35/800x600/wallpaper_07.htm
All of the main electronic control units are inside the car cabin. 2 main points that the loom comes through is near the ABS unit, and behind the battery area, under the black plastic. You could also check your grounding points.
Yes realise that but im just trying to think of the most logical explanation and that one fits my situaiton to a T. That plus the car was driven for 10km in the rain. I find it hard to believe that it somehow flooded the inside of the car.
I have done worse in my s12 gazelle that thing had the computer on the floor with no carpet and holes in the floor 10cm off the ground. Let alone this big white cow.
So before i go ripping apart the glove box ect im going to trace the loom and earths ect. Its going to be something simple/small or chances are tomorrow morning it will be fine because its dried out...
If the BCM is in the drivers kick panel, that is quite close to the wheel arch, and there would be a large amount of water around that area if your plowing through puddles/heavy rain. Trans ECU is in exactly the same place except on the other side. Is possible that the drain holes are blocked up with gunk.
Wipers, lights, blinkers, dashlight, all controled via the BCM.
Auto trans, well, thats controlled by the trans ecu...
Exactly your issues - the engine ECU is seperate- and you've said the engine runs fine...
Realise what I'm getting at...?
Let us know how you go.
Yeah mate i do...
This is my first car with all this sort of crap... And i was hoping that nissan had made this boat a little more waterproof then it appears to be!
Thanks for your help ill get cranking in the morning and go to work with the hair dryer ect .
Appreciate it.
How are you finding the shift kit btw?
Edited by m35stagea
Oh, another thing just to let you know to help you out... If the car doesn't start, don't crank and crank and crank it. The starter motors are a little fragile to cranking forever (they get hot quick), and are not cheap.
Shift kit is great. Mine is a bit different to yours, as I have a different trans set up to the Series one cars from the start, but there are lots and lots of series one guys that are very happy with the kit. Firms up the shift, still smooth on low power upchanges. PM "jetwreck" if your interested in it- but he generally does group buys from the states with the kit(ie might have to wait for a little while).
If you want to get the hair dryer out, take the battery compartment cover off (just a few plastic clips) & behind the battery is a couple of main fuse boxes. They just happen to be under the windshield & maybe there a drain hole that is blocked that could make that area wetter than normal. It's not what I'd call the most likely cause (battery is number one as I've experienced strange things when my battery was low, same as Dale), but if you've eliminated battery then look there as an easy place to start.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
