did some more work to the RB26
pulled out the pistons..
one was like this
1005730_10201538811095102_380223698_n.jp
ummm... okay...
got to the crank
ugh :( thats ugly
1002129_10201538802254881_644387388_n.jp
bearings on number 2.
finished up the the night
1017514_10201544655001196_607812463_n.jp
so far, i sat down and had a look at my plan. scrunched it up and put it in the bin.
f**k this shit. meisters are for sale. going to buy forgies.
also need this finished, in the car and tuned before the first of september, so broke days and busy nights are ahead!
spent some money today...
R32 GTR airbox with snorkel
Long nose R33 GTR crank in immac condition
all the hotside standard piping
also spoke to an engineer...
all i have to say is.
work on friday was f**ked.
but then it was like christmas...
factory GTR airbox and snorkel
1001016_10201592345833437_875430722_n.jp
RB26 sump, cut and shut to fit a RWD
1003016_10201591943263373_2111514403_n.j
gave it a good clean and filled it with water. held it no worries after sitting for a few hours
and then mocked up the Tomei sump baffle. fits nice :)
1077341_10201593958753759_276760052_o.jp
and finally zayno starting to prep the other side!
not long till i get her back...
thanks kasko!
hows the cruise going? haha
Hedley from James' race engines came past my shop today to pickup the block, crank and girdle.
great guy! i think i might have this thing running before the end of august.
okay bottom end details
87mm cp pistons and rings to suit
ARP rod bolts
machine, clean block etc
balance/polish crank shaft
ACL race series main and conrod bearings
ACL MLS performance gasket kit
rebuilt stock pump
new bottom end seals(main seals)
assembly
get it back, bang on the ARP head studs and torque the head down and ill start putting it all together :D
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
