shit just got real!
970460_10201723373189039_1229511010_n.jp
fresh engine on the stand! raf raf likes this.
1150196_10201723378509172_525417506_n.jp
just need to clean up the bolt on bits, bolt the head down a new water pump and timing belt kit and im ready to put it together!
thanks dude,
still a bit left to do.. ran out of cash again lol. 87mm pistons make it an rb26.3 lmao
some more body work was done.
both sides in hifill
1095074_10201701384239329_1756891458_n.j
933931_10201701406359882_1770990297_n.jp
i used james race engines, i cant recommend those guys enough
they picked it up and dropped it off, kept me up to date, informed and explained every thing to me and made sure i understood, and really made me feel important.
the biggest wow is the quick turn around time, Hedley and Scott dont muck around one bit!
http://engineaction.com/photos/james-race-engines/.
Not much so far. Cleaned the cold side and mocked it up.
Bolted the oil pump on.
Also, if your cars never had an oil pump change. Change it. Old pumps gear was cracked! Time bomb!
Yep pretty scary considering so many cars are out there with unopened engines. Might finish cleaning the cold side tomorrow and bolt everything up :) cannnnnnotttt wait until we put it in
New pump was always on the cards for mine. 170k on it and oil pressure was shithouse . New pump fixed it. $400 for the pump ex Nissan . Labour was the killer on it though.
  • 3 weeks later...
smallish update.
cleaned up the cold side.
ever noticed that the ports look like ball sacks?
533946_10201730687611895_2075338691_n.jp
led dash lights came in
1146507_10201779571913972_648291753_n.jp
rear main, oil pump and sump sealed up and bolted down
So bit of an odd update.
Im considering stripping the car and scrapping it when I get it back.
Im over it.
I dont know why. I just am.
Il keep the motor, wheels and kit though
Im over it.
time for a vl?
Im over it.
Well that was a waste of time and money then.
So hell bent on getting a R32 GTB Replica Twin Turbo happening with full wide guards etc.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
