yeah i was watching a movie last night and felt like my eyes were normal for a bit lol.
okay not much progress, besides booking it in for a tune with a very very well known RB workshop who visits melbourne here and there :)
so all that is left is get some money together for the ID1000s and fix the earth issue in the dash that is stopping the climate control and head unit from turning on
  • Like 1
so.
after MONTHS of trying to pin point the source of a missfire,
i had a Powerfc plugged in with a stock basemap and a 5k limiter (because still running it in)
and what do you know, shes SMOOTH as f**k!
  • 4 weeks later...
Bro m not sure what to expect with the new story but what I know is you're the most unlucky son of a b!tch I know, so I sincerely hope this is good news lol
Edited by gtr judd
had a photoshoot lined up.
besides little things like belt squeels etc, the car was perfect.
washed it etc on friday night. it was looking pretty as ever :)
picked up my panel beater and off we went, to meet the photo dude.
long story short, smokes billowing out the driver side of the bonnet. have a look at the PFC and everything is in order.
da f**k?
pull over, mate pops the bonnet. f**kING FIRE!
THE FUSEBOX IS ON FIRE!
like a man on a mission, zayn empties his sprite into the fusebox and puts out the fire.
we stood there and laughed, and laughed and laughed, and maybe called a towtruck. but laughed again,
it could have been SO MUCH WORSE.
fast forward to this week end.
new bodyloom is in. i dont know why it caught fire, but i suspect its the bodgy wiring job by the previous owner.
should be good to go on saturday :)
soz. was up watching ross kemp docos.
booked in for a tune at Racepace.
the excitement is mounting. the car has been running beautifully, and it seems like this motor is very very torquey. all it wants to do is kill tyres lol
Untuned... Smokes tyres... Those two should never be in the same paragraph. :domokun:
You got injectors yet? I haven't heard from you for a quote mate... The Xspurt 1000's are on special at the moment. ;)
  • 3 weeks later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
