  • 1 month later...
yes.
okay, for the past few months i have been getting the motor to run right and pretty much cleaning the old girl up for a rwc
found a mint R32 GTR drivers seat thanks to my mate up in newcastle.
back onto the rwc issue. it is SO f**king hard to actually get one in victoria... the tester wanted all the interior trims to be put back in, but overlooked the 3" exhaust, stretched 225s and height. wtf
  • 4 weeks later...
sup niggas.
no updates lately as i have been swamped with work.
at the moment the car is sitting tidy on the BBS RS'
i tried to get a dodgey rwc but no luck, so ill take it into the shop up the road and see what needs changing and change shit, then take it into epping kmart tyre and auto(they dont know shit about cars lol)
i have parted with the RB30 block.
reason being it wouldnt be worth building.
the alternative is across the ditch in the land of sheep f**kers.
yes, RIPS.
a forged RIPS short block would work out to be about 7.5k AUD excluding shipping and tax.
that includes stock balanced crank etc, collar, billet rods, pistons etc, blue printed, oil pumps.
so all i have to do is buy a head, reco it, throw in some cams, slap it on + turbos etc and tune it.
i know youre all dying for pics.
but ill be a cock tease and let you all wait till i do the feature and throw some pictures from there onto here.
yes, i said feature.
complete RB26 just popped up for the right price, has a spun bearing with minimal damage, so checking it out tonight and if its all sweet ill put a deposit.
rips cratey looks to be on hold for now, ill run the 26 till she blows.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
