any way to check timing belt wear?
By robbo_rb180 · Posted
Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering. Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car. Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
