Hi all,
My cousin has recently purchased a 1999 Nissan Maxima A32 30GV with 222,xxx km for a great price.
The car is 100% stock and mechanically A1. However it has some annoying electrical issues (which we used for bargaining).
1. The remote central locking does not seem to be working. Central locking seems to work fine if we use the actual key to lock/unlock the doors. The original owner told us the remote function stopped working recently and suggested the fix is as easy as changing the battery (CR2025) in the remote. We have put a new battery in the remote (tried both directions) - Still doesn't work. Any suggestions before we go and get someone to install a new central locking system etc?
2. The stock radio seems to forget station memory and sound quality is very tinny and weak - it sounds crap. We have tried adjusting bass and treble settings - No difference. To the best of my knowledge I thought these cars have "premium" sound. Is there any other possible settings or connectors we may need to change/tweak or do we just change the head unit?
3. The electronic in cabin boot release does not seem to work. We can hear a clicking sound in the boot. We also tried adjusting the cancel tab in the boot - makes no difference.
Cheers
Hi all,
the remotes on those are prone to dying. they are available new from nissan but require programming. that is the easier option as those cars had remote alarms on them as standard and adding another remote unit over the top of the existing will cause hassles.
does it have the eurovox radio (long display that runs across the radio) or the clarion one (display on left side) the eurovox is crap. given the age of the car I would replace all of the speakers as they would be dry rotted by now. 6'5" front and rear.
Cheers
they had a lock out on them the only way to open it was with the key. if that IS the case look at where the catch is on the car. you will see a tab that pokes out at 90 deg - pull that UP and check the electric release.
Thanks Chris.
Regarding the remote - Is it worth getting a genuine nissan item or an after market remote we can program ourselves eg. http://www.amazon.co...s/dp/B003RB63EQ
The headunit seems to be a Clarion (pic attached)
Edited by iseekool
yes there is. the round clarion item runs the 4 speakers. it has a bit of grunt and that also tells me that you have the clarion tape radio with the external 6cd in there. if you wnat to keep it looking stock I sell Ipod patches for those decks.
Thanks Chris.
get the correct one for the car FORGET going aftermarket.
You are spot on. The surrounds of the speakers are gone, no wonder why the sound is terrible.
My cousin plans to keep the stock HU. He also figured out how to store stations. He doesn't want to spend too much, as he just wants something that is decent for day-to-day (he isn't a car enthusiast). He is looking at just "drop in replacements" what's your opinion on Pioneer TS-G1644R or any other speakers in that ball park price range? Or is he better off saving for better speakers? I'll tell him about your iPod connectors - I'm sure it's something he wants.
Hi Chris, it seems the head unit is actually stuffed - it seems the stations get "dropped" randomly and seems to just shutoff randomly if it has been on for long periods of time. The CD player also seems to no longer play CDs even genuine CDs.
Do you have any recommendations for replacement HU? (he is looking at either clarion fz709 or cz309)
Is it worth the effort with keeping the external factory Clarion amp?
Any recommended installers in Melbourne?
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
