This bov will handle serious power, is made in the USA and is quality built. Designed to recirculate (plumb back) it will vent just about any boost level turbo combination you can throw at it. Comes with a brand new generic flange in case you dont already have a vband flange. Comes with 2 springs depending on your vac level. I great performance part only been ony car for a few short months.
$220.
Why buy a new one for 400 when you can get the same deal for almost half price.
If you don't much about tial products, have a look ar
https://www.sau.com.au/forums/topic/398228-tial-qr-bov/
Guest
