Hi All,
I am not sure if everyone is aware of this, but the founder of these forums and the club, Christian, has had a very serious medical issue 2 days ago. He is very lucky to be alive.
His wife Bec sent the following update:
For anyone that doesn't know Christian had an aortic aneurism and had emergency cardiac surgery on Wednesday as it split his aorta and coronary arteries. Thankyou for your love and thoughts, I know he appreciates them so much as do I. He is stable now but on a ventilator which they hope to get him breathing on his own today so they can get him off it. if you could please send him thoughts of strength today that would be so helpful. Bec
This club would never have existed without Christian's efforts, and equally, most of us probably would never have met without his creation and maintenance of these forums.
And, he is a damn good bloke who has never failed to try to do the right thing in the 10+ years I have known him.
All the best with your recovery, Christian
https://www.sau.com.au/forums/topic/398231-christian-prank-very-unwell/
  • Replies 67
Prayer of comfort for you Bec and Christian and other close family.
Prayer of thanks that certain brilliant medical staff have been able to diagnose an extremely difficult problem and so far, fix it.
Prayer that God willing, a full recovery is in order for a passionate gentleman who has been an instrumental backbone of the construction of one of the best car clubs in this whole nation.
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
