  • Replies 46
I have a pair of T517Z's for sale if you need some decent turbo's. I pushed 400rwkw on a stock 26 with them.
Cheers
Justin
It would be nice to have 400 but it's a rwd BMW so I want to drive it without it being a burden thanks anyway mate
What boost and what fuel???
Yeh would like to know the same thing, also exhaust size? (front pipes and cat back)
23psi, 98 (this was way before e85 was even available.... 2005)
trust dumps and a 3.5" exhaust, unported stock manifolds and trust intake pipework.
The car ran 10.6@138mph on these turbo's. Great on the road, spool was really good for the power.
Cheers
Justin
Just buy a friggin T04z imitation, eBay manifold and bang it together.
Stuffing around with all these miss matched rubbish turbos will do your head in and never work.
Atleast if the imitation turbo craps out latter your budget may then extend to buying a genuine Garrett and everything you've fabbed should theoretically fit right up.
It'll cost you under 1k and be done in under a day. As opposed to friggin around with some wacked turbo combo that someone on the Internet said might work okay, but turns out to be shit.
LOL!
Blake just do what Risking said but use a Kando turbo. A T67 on an RB26 should be at least as good as it is on an RB25, if not better.
One of those NZ performance manifolds, a kando, a tial 44.... no more than 1600 in parts and will save you the heartache of all these random ideas.
If you still have that 3040 laying around then use that, theres $800 you dont need to spend. If you need a housing for it:
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-GT35R-GT3582R-GT3540-GTX-A-R-73-10cm-/290698119545?pt=AU_Car_Parts_Accessories&hash=item43aef54979
DONE.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
