Hi all
Tuning day this Monday 23 April 8am - 5pm
Me and the old boy will be up there trying to give each other a whopping after the extremely long awaited track renno's (modded 33GT-R and a modded 34GT-T)
Any one keen to come out for a wrap or just for a look, let us know.
Should be an awesome day ;-)
Cheers,
Brendan
https://www.sau.com.au/forums/topic/398278-barbagallo-wascc-track-day/
Ok first up,
Paul: I owe you a massive apology - did not even click when my father and I met you today! haha
All this time I've been looking forward to meeting you and I was away with the fairys at the track when the opportunity had risen! Pretty funny considering I'd been looking through your build profile and then didn't even recognise the car today, EVEN WHEN I SAT IN IT TO HELP YOU BLEED THE BRAKES haha
Ahh well, shame about your brakes mate.
The old boy and I had an awesome day battling it out with each other. Made for some awesome video footage, inlcuding my classic moment spinning in to the paddock (no thanks to the fluid spilt on the track) My 34 was far quicker than ever today thanks to the new brakes, suspension and wheels/R888 tyres, which helped keep up with dads 460awhp beast a little better.
Look forward to catching up with you boys and the RB toys again soon.
Cheers,
Brendan
Ok first up,
Haha, no worries its all good :)
Turns out it may not have been the brakes after all, possibly a stuffed wheel bearing, but we'll figure it out soon enough. One of the benefits of the tuning day is getting to grips with teething problems in the car when there is no pressure to perform ;)
The Blake boys plan to be out at the next tuning day coming up 19th May with 2 freshly re-tuned skylines ;-)
Should focus on that one first eh fellas?
Be good to get a clan of skylines running together - The family/friends will be out with the video cameras aswell so will be good to get plenty of RB action if a few others come out.
Cheers,
Brendan
Good stuff.
Yeah got a few with the GoPro's but they are massive in size so it's too much of a mission to upload them on the net.
Got some good previous vid's of me and the old boy which I'll put up when I get time.
Look forward to meeting you Goran.
Will be there with mate in R33's
Still deciding if I should change to E85 and chase more power or set up suspension and get most out of current set up.
Any photos or vids from last track day Brendan?
Uploaded a few vid's on to the youtube account - you can watch them on my channel; "SCR34MER444"
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
