Ok guys I have wrote this up a few days ago and done Alot of research, my car at idle is bouncing from 1200rpm to 2000rpm, I have a r34 gtt, I've been reading all day and I've replaced the afm, didn't fix it, tried fiddling with the tps, it jst changes the idle rpm but stil was jumping, I think tps is the one closest to the radiator on the tb? Ok now I tried the one at the rear of the tb, and it didn't change the revs or how the engine ran at all, I tried disconnecting it and still didn't do anything so I'm guessing this is the problem? I'm hoping it is cos I'm hopeless at working on cars and if it is I'll be stoked with myself lol, of this is the problem can any1 tell me what this sensor is called so I can get another?
Pull all intercooler Pipes off, inlet manifold and checked for cracks/split hoses and anything else that doesn't look right, everything seems to be fine, I noticed the butterfly in the tb is open when the car is off? Not sure if that's correct or not? Car is not blowing any smoke and is still jumping while at idle and is consistent, no powerloss, the sensor on the front of the plenum does adjust the idle so I know that's still working, the one at the back still does nothing to the idle when playing with it, even of unplugged so I'm still guessing this is the problem, I notice there is a bit of blowby in the piping but not a lot, checked radiator fluid and the oil, put everything back to stock including stock boost solenoid and blow off valve, still nothing, checked vac lines, hose clamps, battery terminals, afm, plugs were done a month ago ngkbkr7es, cleaned pod filter, reset ecu, still go no idea
List everything you've done (I mean everything, mods, tweaks, servicing etc) between when the car was working properly (idled at normal revs), and now.
Take a look at the charcoal canister (black cylinder with 2 or 3 hoses connected) and see if you haven't blown one of the hoses off when you upped the boost pressure.
I don't know about RB25 Neo's, but I think NGK BKR7ES plugs could be the wrong ones (BCPR7ES might the correct one)
Checked the canister, all fine, pulled the main pipe that goes to front of the turbo off and no splits or holes, checked the alloy piping that goes into the induction pip and looks fine also, it has to be the sensor on the back of the plenum...
All I did was put the boost controller, I put it on backwards at first n hit fuel cut, I then switched it back n I was idling high, it then got worse n now it jst revs from 1200 to 2000 consistently on idle...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
