Hi all, I am going to move on from the rb's so I will be clearing out all my gear, I will update the list as I go.
  • R32 gtr rb26dett complete engine package, has a mines stage 3 upgrade. Engine runs great has good compression and can be tested for buyers. Included with sale of engine twin HKS low mount turbos, HKS cast dump pipes, trust front pipe, Mines afm's, silicone cooler pipes & factory BOV's nismo 600cc injectors mines ecu tuned for package $4500.00 can be heard running turbos are 2510's or 2530's not sure but has 2530 on gold plaque on the ecu..
  • gearbox for above engine from r32 gtr (push type clutch) $500.00
  • 100mm gtr intercooler good condition some bent fins etc $250.00
  • HKS twin2835 high mount kit with 60mm wastegates may seperate manifolds, turbos & gates etc compressor wheels need replacing on turbos. Would sell complete for $3000.00 or seperate if I have buyers for all parts 1st. gates-$650ea manifolds with balance pipe-$1100.00 Turbos-$700ea
  • Huge GCG drag wastegate 65mm vband type new never used cost ove 1k will sell $800.00
  • z32 tt lsd diff $300
  • R33 gtst lsd $150
  • r32 gtr master cyl $120
  • R32 gtr clutch booster & master $120
  • R32 gtr abs module $100
  • R33 gtst radiator $75
  • R33 gtst turbo (leaking seals) $100
  • R32/33 power fc & hand controller $700
  • Sard 720cc gtr injectors $600
  • Gtr rb26 rwd sump $250
PM for pics pick up in Brisbane I will post at your cost on smaller items.
https://www.sau.com.au/forums/topic/398313-time-to-clear-my-garage/
I have a few PM's requesting parts from the engine package, I will seperate parts if I have buyers for turbos, afms, dumps & front pipe. Feel free to make an offer on any items. That said I have more to add.
  • RB25 ser2 head 79k's $400 (complete head)
  • Stagea rear diff (auto) $50
  • Stagea sump front diff (auto) $100
  • AWD rb25 short block from stagea $400
  • R32 gtr stearing column with key $120
  • 5 stud hub conversion $450
  • lexus 1uzfe v8 engine & harness $950
  • RB25 ser2 yellow jacket coils $250
There will be more to come feel free to ask if you are searching for something I have heaps to clear.
Edited by rb30dett
What shaft play is on the turbos?
Can you identify them? If they are HKS2530's i may be interested.
What is the engines internal specs and condition?
Hey mate, willing to pull the yoke off the 50 dollar stagea diff and send to adelaide? please! need one asap, thanks
Yeah mate it will cost ya$50+ post pm for bank details
There is no play also only selling complete at this stage, I will seperate if all bolt-ons sell or long engine sells first. Don't know what they are until the engine is out sorry. They have HKS cast into the compressor covers is all I can see.
Hey mate what is the condition of the yellow jackets? How old?
To be honest I don't know how old they are, they were on my rb25 when I bought the car it ran fine but I had splitfires sitting in the shed so I swapped them over on the 1st plug change. I can send you a pic if you want? They have not been used in over a year.
Also deposit taken on engine package. Please no more pm's about splitting the package thanks.
The RB25 Series 2 head, is this the later 97 model one with the Cas sensor change (series 1 is silver, late series 2 is black same as r34) ?
if the silver cas ill take it :)
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
