Okay about 2 months ago I had got the dodgy exhaust system one of the previous owners put on ripped off and redone.
2.5inch, high flow cat, 1 resonator. But I left the cannon on it because I couldn't afford anything more at the time...
Obviously the thing to too f**king loud, I didn't really care and got used to it. Clearly the cops didn't.
Today I got pulled over, yada yada, $88 fine and EPA will send you a letter in a month.
The plan now is to rip the cannon off and throw on a twin tip muffler. The question is, will this pass through EPA? (Provided it is under 90db).
Thanks in advanced.
EPA emissions? that is the letter in the mail one? they dont look for noise just the emissions the car emits defect for exhaust noise and having to go get a check to make sure its 90db is the one you should hope it is? should be easy to pass if it dosent you need another muffler or resnator in it
90db isnt very loud at all, one resonator and a twin tip muffler is wat i run and i dont think mine would be under 90.
best bet would have it tested somewhere... judt dont know were ud dtsrt
  • 3 weeks later...
"... the vehicle bearing Registration Number XXXXXX is excessively noisy and therefore likely to be exceeding the legal noise levels for the vehicle..."
"The noise test and anti-tampering inspection must be undertaken by an EPA approved Mechanic by the compliance due date which is Wednesday, 23 May 2012"
"- the engine test speed for your vehicle is 4800 rpm and the legal noise level for your vehicle is 90 dB(A)."
Again, I have a stock standard RB25DE with a K&N high flow panel filter, and a 2.5" exhaust system with a high-flow cat and 1 resonator + cannon (Will replace shitty cannon with twin tip muffler, hoping for less than 90 dB), stock extractors.
Will that pass the test? I'm just curious about the 'anti-tampering' part of it. Is a high-flow cat considered to be 'tampered' with?
Thanks.
would put money on you not passing with your current set up, my guess would be 97-98 decibels.
if you could get away with the plate that would work (again asking as they didn't see it. perhaps place behind the cat flange with 5 1cm holes drilled in it and only make the plate 1-2 mm thick)
*not sure on how many holes lol
Been there done that when I was on my Ps lol..
Best thing to do is borrow a standard exhaust from someone on the forums (heck im sure someone will lend you it for a day in exchange for a case of beers).
- Take off current loud exhaust
- Put on standard exhaust
- Go to EPA
- Pass inspection
- Put back old exhaust on and return borrowed exhaust
Your looking at about $50 for a case (depending on what your buddy prefers :P), $60 from memory to take the test and the $20 or odd you will be spending driving to pick up the exhaust and drop it back off.. Still adds up alot cheaper than paying a couple hundred and getting a whole new exhaust fabricated
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
