Plan D:-
Shift the Teppanyaki Restaurant booking to Sunday 27/5/12 ???
The Edge Cinema Katoomba is running "Bullitt" on the iMax Screen at 3pm and finishes at 5pm
Cost of movie on the big screen is $10.
Time to cruise back to Emu Plains for dinner at 6pm
I'll leave this option to you Justin :) > your call & would you like to have a cruise from Penrith at 1.45pm (allowing for roadworks) to Katoomba for the film? Or 1pm if going up via Bells Line Of Road?
  • Replies 185
Posted Images
I'm actually Liking the 27th Idea Terry!
Lets Make it 1P.M Meet at Aqua Golf For A Cruise via Penrith Leaving at 1:30 to the Cinemas's then onto Teppenyaki For Dinner? Who Is keen?
Now Everyone has to confirm if they will be coming to dinner! PLEASE CONFIRM GUYS BY THE 18TH STILL!
If the date is changed to 27/5/12 in favour of Bullitt Movie at iMax Katoomba, followed by Teppanyaki at Emu Plains, it might be best don't you think, to approach Nick at the AGM to-day with regard to cleaning up this thread Justin?
I'll try my best to come meet you guys at the meet and then dinner but I won't be going on the cruise I guess.. My mate had an accident in my car and it will be in the shop getting repaired on this date :(
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
