R34 GTR V-spec, lightly modified 260kw@wheels priced to sell, cheapest V-spec around, with a few tasteful mods
- Factory wheels paint charcol
- HKS coilovers
- HKS air filters
- Spit fire coil packs
- Apexi power FC with hand controller
- Apexi elec boost controller
- OS Giken race twin plate clutch put in about 2000kms ago
- Jasma front pipes into 3' hi-flow cat into 3 1/2' rear pipe
- Autometer boost gauge
- Nismo 320km/h dash
- TV/DVD player
- Viper alarm with pager
Car has been tuned on 14-15psi making 260kw@rw
Great weekender, amazing car to drive, first to see will buy
Car is located in Mill Park
Any questions just call Billy 0404 00 66 00
$45000 ono MUST SELL money going back into business
Very regretful sale
Edited by GXE747
  • 3 weeks later...
Quite reasonably priced I have to say - tight market.
Jap History with Logs? > Kms?
Are you the first Aust owner?
Service history here?
Can't help but feel that there's some other modification other than exhaust, hi flow cat and that psi to put out 260. Mostly, that setup would show about 230.
GLWS :)
GLWS :)
I recal seeing my friends dyno sheet for his R34 GTR reading out 253awkw with nothing more than a full exhaust and boost (ableit 17psi on ceramics lol). Still standard injectors, fuel pump, ecu, the works - same said car ran a 12.2 down the creek!
GL with the same mate, car looks very nice!
Thanx guys..
Terry_GT-R34 - thats all the car has. I took it to calder park and had 1 pass and ran 12.0 @ 115mph
I rekon better tyres, adjustment on the suspention and a better take off no probz a 11.8-11.7
A mate went 11.9@114 with just an exhaust, boost restrictor taken out and a twin plate with his r32 gtr
I am the second owner in Oz, car has 71,000kms, all factory books stamped and even the factory spare key still stapled in owners manual
As for service history here, my mate used to own PET modifications. He maintaines the car now out off a private garage
Any further questions please call Billy on 0404 00 66 00
Cheers
  • 4 weeks later...
  • 3 weeks later...
Thanx guys..
Cheers
dont believe ya
or i should be runnin 11.5 with -7s
Edited by w34ponGT
Thanx guys..
Cheers
I would believe a 260awkw 34 gtr run 12 flat. But R32 gtr with exhaust and no restrictor which means running 14-15psi doing high 11s is really hard to believe.
w34ponGT - According to the power your "claiming to have" your very far off the money champ
You say ur cars got 315rwkw but you could only get a 12.1 @ 118, so either ur car doesnt have that power or your not driving the car hard enough
What about a stock engine Gtr, cat back, 12psi running 12.18?
Why do people feel the need to ridicule someone who is trying to sell their car by posting rubbish in their threads,
If you really wanna see proof ask XKLABA, ran 11.3 with 290rwkw on stock turbos
So disappear and let the bloke sell his car
GLWS mate
GLWS mate
+1
Awsome car.
Free bump
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
