Hay ppl
just chasing some advice on head work and turbo selection for my gtr!
Brief rundown on the car/setup
r33 gtr vspec
26/30 (in process)
Rb 30 block (machined)
Nitto pistons
forged rods
ati 1000hp balancer
custom oil pump
arp studs etc
The bottom ends basically sorted i need advice on head work now
i had a gtx3582r with tial housing but ive changed my mind (due to paranoia mainly)
i want to build a twin lowmount setup to keep it stockish looking from the top!
Im chasing 500kw atw (2nd reason for losing the gtx)
Ive looked a bit through the turbo upgrade thread and a bit of research has led me to believe that the garrett gt2871 -10 (gtrs i believe) would be a good choice with ext gates setup!
OPINIONS PLEASE???
HEAD WORK!
Will this work?
I want the car the have a decent rev range so opinions also greatly appreciated!
Tomei type b cams
tomei cam gears
.5mm oversize valves
titanium valve springs
retainers
Valve guides
Required machining!
OPINIONS PLEASE??
What kind of lag would i expect with this type of setup?
I know theres prob heaps of other parts involved so if you were to build the head what eould you do in these circumstances!
Thanks heaps
https://www.sau.com.au/forums/topic/398361-need-some-guidance/
  • Replies 83
Go back to a single!
What he said.
And dont bother with o/s valves, Just tidy up the ports and bowls, I am using the supertech valvetrain with o.s valves cut back to near standard, With the 37/88 on a 30 bottom end you will give nothing away to any twin setup in terms of response and low down grunt.
Just do it, you wont regret it. they can shove the twin turbo goatf**k where the sun dont shine.
Problem is - he is in Melb.
You need an arsehole that can take a firehydrant if the cops pull him over with that, and the likelyhood given how things are down here ATM is highly likely...
It's basically engine out, install stock motor and then re-reg with a different motor & start again. Fark that.
As Paul said look into the GTX lowmounts if you want stock-ish appearance, but the custom piping will mean it's really quite obvious.
Do not go near the -10s/GT-RS. Worst turbos you can possibly buy. I cannot think of one user who has taken them off, and regretted doing so - that's how bad they are.
Hate to say it but if you want to have a stock appearance about as much as you'll make is 400-440rwkw with HKS 2530s, and when I say stock, it'll look 100% factory.
Have a read/search of the main FI section. You'll see they are a surgy/laggy mess for the power they make. Totally mis-matched like the HKS 2540 of old.
470rwkw+ you ain't going to get outta stock appearance low mount setup
Only way is the GTX turbos, but its pretty obvious they aren't factory then and you might as well have a big single.
Just add a shot of nitrous if you wanna race it or whatever.
I'll be going rb30 soon. I'm running hks gt-rs 441AWKW @ 24psi on a rb26 full boost by 5000rpm on e85
Should be much more responsive with the rb30 with full boost around 4000rpm. I have no comp surge and will be running 28-30psi.
We will see what result will be, let see if I can make 470awkw with a stock low mount look :)
Edited by destrukshn
looks stock and 470rwkw+, sounds like a challange
I to am building a 30 with RSs ( though was looking for T618ZS ) and was aiming for 450, though I have seen a couple of poeple on this forum make 500rwkw+ from RSs
Dealing with the backpressure from the mismatched wheels when the exhaust valve opens is , I think, the key to making then work
Lets face it if you want 450rwkw+ that looks stock then pretty much your only option is RSs or T618Zs
if you really want to use those turbos, i wouldnt be asking on a forum for ideas on if/how to get it to work.
Youre better off going to a good builder with a reputation for making things work and ask them, hand over your $$$ because once youre up there getting the max out of something, its takes every little bit.
everything counts.
Piggaz and N1GTR are up to mid 400s with -5's, they have well sorted setups.
most people net mid to high 300s... its the setup as a collective
everything counts.
Honestly, it really depends on the person, what they really want for the car. A lot of people on this forum are misguided to those who talk up the -5s. If you driven a -5/HKS 2530. Yes it is responsive but every advantage will have some kind of disadvantage. My opinion of the -5s/2530 is that it lacks top-end, by about 6000rpm it is about at its limits. This is coming from someone who had a pair of HKS 2530s. With a set of HKS GT-RS even at 9000rpm on my car they still want to keep going. Disadvantage is yes it is laggier than a set of 2530s. Circuit wise 2530s, Drag wise GT-RS.
Mix and match an RB30 with a pair of HKS GT-RS, i could improve the responsiveness of the car and probably still make more power than N1GTR and Piggaz. Actually i made 441AWKW on a 2.6l bottom @ 24psi none of this RWKW rubbish. The outright power was more than they made on their respective RB28/30s. Whether it was more drivable on the road - probably not.
With my RB30 to be completed in 3weeks, tuning will be done on both 98/E85 @ 30psi. We will see the response/power output compared to the -5's. ;)
So really it is up to you, my opinion is -5s aren't all they are said to be. Depends on your engine package and since you're going RB30, it won't be as laggy as those who are on 2.6l and cry about them....
. Actually i made 441AWKW on a 2.6l bottom @ 24psi none of this RWKW rubbish. The outright power was more than they made on their respective RB28/30s. Whether it was Faster - probably not.
fyp
Having an extra 20kws right up the top of teh rev range does not make it the better package when you are forever waiting for it to start moving forward
Dont forget both Paul and Steve made more power going back to -5s at less boost too from memory
iirc Steves RB30 still didnt see full boost until after 5000rpm, same goes for GTRNUR's RB31 with GT-RS'
Im sure they can comment to confirm
Either way, I'm not going to tell you your setup is no good, its up to the owner to setup a car how they like, and if you like the GT-RS' than that is fine, and I cant really talk because I'm 95% sure Im going to throw a T04R onto a 1J lol
Do you have a dyno sheet of the 440kw 2.6 run? or a time slip?
fyp
I actually wasnt waiting forever to get it moving. Depends how you're driving e.g. if i was in 2nd gear going around a roundabout it will be laggy. But if i was in first gear at the lights, actually didnt feel laggy at all better yet it was quite similar to the 2530s. This is a 6speed R34 GTR anyway. No changing any diff ratios. Probably couldve outdragged N1GTR or Piggaz on a 2.6l :P
Lets see if i hit full boost before 5000rpm. My 2.6l would hit full boost by 5000-5500rpm. Not sure what is up with other builds on their respective RB30s. Dyno sheet below: Not power was @ all fours and not RWD as theirs. Either way someone can run my graph of RB30 HKS GT-RS compared to theirs and compare apples to apples. It is hard to compare when the run below was done on a 2.6l bottom and run on different dynos.
I am not too sure as I didnt get a dyno graph with RPM. The redline for the car was 9000rpm so you can estimate if you like lol. As i said, the car was laggy if i am driving through the streets around on 2nd gear but if you drove from 1st and kept in on power. Was a monster! :P
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
