Ok so this is it I've had a oil leak in my r32 gts4 since I've had it (4weeks) and I have had it with putting card borde and shit under my car :( I have located the leak coming from just under the the manifold at the rear of the motor I can see it dripping down under the manifold on it my external waste gate I got a mirror and I can see the oil forming on the bottom of the manifold bolts but can oil come from there and if not whats around that area that the oil
Could leak from?? HELP!!!
https://www.sau.com.au/forums/topic/398382-major-oil-leak-help/
Have a look above the manifold. It is extremely common for the rockers to leak.
^^^this is where it will be coming from, replace both rocker cover gaskets including the half moon seals and that will fix it
  • 2 months later...
I was going to sugest your oil drain line from your turbo.
Give it a good clean with degreaser and a high pressure hose, get it as clean as you can.
Then start having a look and see were it is coming from.
Could be the gasket has poped, or a bolt isn't tight enough and the prssure is casuing it to come out when the engine is running.
yeah thats what i first thought so i replaced the gasket, degreased the shit out of it and lay under the car with it running and i could see oil slowly bubbling out from one of the bolts that goes through the turbo core into the compressor housing. I couldnt get a socket or spanner up there to tighten the bastard up tho. Also seems to be leaking from above the manifold at the back some where. The joys of a 23yr old rb20det i guess
i got this problem also have you done a 100k service on the car yet, its a O ring seal that needs to be replaced which gets replaced when you do a 100k service, most ppl know the name of this seal but i forgot it hope some one can elaborate on that
yea thats it the cam and crank shaft seals should be replaced with that 200k service but its also called 100k , which water pump crank and cam pully and seals along with the belts should get changed on that service if it hasnt been done then take it back to ppl and say you didint do the right job and get them to do it,
other than that get a water pressure test to see if it is headgasket, i did on mien and was all good, and a cylinder compression test which i going to do that next
Edited by BRUNSKIGTST
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
    • Brakes definitely won't make him faster. They only slow you down. 😛
