Ok so this is it I've had a oil leak in my r32 gts4 since I've had it (4weeks) and I have had it with putting card borde and shit under my car :( I have located the leak coming from just under the the manifold at the rear of the motor I can see it dripping down under the manifold on it my external waste gate I got a mirror and I can see the oil forming on the bottom of the manifold bolts but can oil come from there and if not whats around that area that the oil
Could leak from?? HELP!!!
https://www.sau.com.au/forums/topic/398382-major-oil-leak-help/
Have a look above the manifold. It is extremely common for the rockers to leak.
^^^this is where it will be coming from, replace both rocker cover gaskets including the half moon seals and that will fix it
  • 2 months later...
I was going to sugest your oil drain line from your turbo.
Give it a good clean with degreaser and a high pressure hose, get it as clean as you can.
Then start having a look and see were it is coming from.
Could be the gasket has poped, or a bolt isn't tight enough and the prssure is casuing it to come out when the engine is running.
yeah thats what i first thought so i replaced the gasket, degreased the shit out of it and lay under the car with it running and i could see oil slowly bubbling out from one of the bolts that goes through the turbo core into the compressor housing. I couldnt get a socket or spanner up there to tighten the bastard up tho. Also seems to be leaking from above the manifold at the back some where. The joys of a 23yr old rb20det i guess
i got this problem also have you done a 100k service on the car yet, its a O ring seal that needs to be replaced which gets replaced when you do a 100k service, most ppl know the name of this seal but i forgot it hope some one can elaborate on that
yea thats it the cam and crank shaft seals should be replaced with that 200k service but its also called 100k , which water pump crank and cam pully and seals along with the belts should get changed on that service if it hasnt been done then take it back to ppl and say you didint do the right job and get them to do it,
other than that get a water pressure test to see if it is headgasket, i did on mien and was all good, and a cylinder compression test which i going to do that next
Edited by BRUNSKIGTST
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
