I purchased my Silver 350GT Coupe this week from Brisbane and it already had a loose ball joint (aparently not a big issue yet) that the seller told me about.
He also informed me that a mechanic quoted him $250 to get it fixed, basically what it does it make a rattling sound in the suspension when you go over bumps and trust me there's alot of those on Mackay's shitty roads, so i am wondering if anyone has experienced this problem and knows how to fix it at minimal cost as i am purchasing an exhaust setup so i don't want to waste any money on getting a mechanic to do it.
Plus i want it fixed asap as the rattle sound annoys me!
any feedback would be greatly appreciated.
https://www.sau.com.au/forums/topic/398398-ball-joint-issues/
I am also having ball joint issues, but the housing for mine is cracked, it clunks on big bumps. I was thinking of just swapping out the upper control/camber arms as it looks like aftermarket ones come with a new joint, but I'm not sure if this is the case or if it will solve my problem.
As for mackays shitty roads, I live in gladstone, your not alone in that situation Haha.
Seano, check that it actually is the ball joint - the most common V35 defect is the lower control arm bushes going (which mine have done), and they make a knocking noise too.
very true man, i will look into it. How much did they cost u to fix?
yeh bro mackay roads are a f**kin joke ahah, i'll have to look into what's actually wrong with it ay
I bought the lower contorl arm bushes in a group buy on here a few months back for a bit under $100 (from memory), but I haven't had time to fit them yet - they need to be pressed in.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
