Hey all,
I recently bought a 95 r33 GTS-T and got my grandfather (mechanic but knows nothing about turbo's) to change my oil and oil filter. I saw him pour just over 4 litres in and thought 'isn' t that too much?' the oil checker showed full.
Then I installed a second hand bleed valve and just guessed the correct measurement, gave it flat stick and noticed that the needle had moved up to the line inbetween 0 to 7 mmhg. This line equates to roughly 11 psi if i'm not mistaken. Thrilled with the massive power increase I took it up to 4th gear twice. Then I took the bleedvalve off to try and feel the power difference. To my HORROR and shock I noticed a huge cloud of smoke blowing out of my exhaust. Now I'm burning up oil and the smoke is still there. (although the smoke isn't as bad as when it first happened). I thought the problem went away because it was still spooling fine on stock boost and couldn't really see the smoke anymore but that night I went to the runs, and noticed my oil went from full to low. It's burning oil and I assume I've blown a turbo seal maybe? Okay now here's the question:
1) Does anyone know a good mechanic?
2) What do I do?
3) How much do you think it will cost assuming turbo needs replacing?
I'd have a guess and say that you would be up for an engine rebuild :(
you have probably blown a piston ring
Stock fuel pumps arent that good and increasing boost without a tune is a recipe for detonation, especially 4th gear runs..
If the engine sounds okay you might be right, more like the turbo. The turbo can burn lots ot oil very quickly creating lots of smoke :( So this could be the problem, for your sake lets hope so!
If you definatly know its the turb and you do the work yourself you will get away with it for whatever you pick the std turbo up for see in the for sale section. If there isnt one for sale do a search there would have been in the past and it will give you an idea of what there worth.
The job is pretty sraight forward (just 4 lines with banjo fittings and bolts and hose clamps hear and there to attach manifolds etc. from memory) its abit fiddly but you save $$$ and get the satasfaction of doin it yourself and learn abit more about your car.
Dont know how much a mec would charge have to be afew hours at least.
Good luck, hope it doesnt end up being anything to serious.
Theres a good chance its not gonna be anything to serious with the engine if youve still got std ecu correct me if im wrong but if you dialed in tomuch boost you would have hit fuel cut well before the std pump ran out of huff, i mean whats the point in nissan putting that sort of protection on the car if its gonna lean out and destroy the engine before it kicks in. The std ecu is very protective of the engine but i guess anything can happen
Tell your Grandpa to do a compression test. If that checks out, your problem is most likely turbo related. Provided a wheel hasn't contacted a housing, it can be rebuilt & balanced to better than factory specs for very reasonable cost.
Hope that helps ya out, Bro.
(the line inbetween 0 to 7 mmhg. This line equates to roughly 11 psi if i'm not mistaken.)
6 or 7psl would be more accurate. 7mmhg is about 14.5psi. and the only line between 0 and 7 is halfway inbetween. B est advice I can give you is..........
1) STOP making assumptions
2) Forget all the advice you've just read in this thread
3) Search this forum to find a "well thought of workshop"
4) Go to them before you do anything else stupid
:werd:
thank you every1
I believe my engine is fine because I still have power and no sounds at all.
I can rev the **** out of it up to 7 grand, it performs great.
Oil burns, so I think OTTO is right about the turbo burning up the oil.
HOPEFULLY ! hehe
what i would do is take it to a mechanic and get them to tell you whats wrong with it. pay them the money and then you go out and fix the problems yourself.
There is plenty of stuff in these forums going to sale.
Yes LAL thanks for that advise I think I will do that actually.
Do you have oil coming out of your BOV? Higher boost means more blow by, which means more oil through the intake. This can cause alot of oil to be burnt.
If you think you can give it a go (get grandad to help) try pulling an intercooler pipe off, and checking for oil inside it. If you can find alot of oil there, that MAY be your problem, esp if everything else is ok except for the smoke.
If there is oil through the pipes, clean them out. Also, remove the intercooler and give it a flush with metho or similar - clean all the sh1t out.
If you ever have to turn up the boost again, fit a decent catch can. Not always necessary, but better safe than sorry. Oil mixing with the intake charge isnt ideal.
OR, as Neil points out, take your car to an appropriate mechanic.
I am running 14 psi on my gtst. Have no problems now. Have a duel stage turbo smart controler. All i had to do was change the spark plugs and put the right gap on them. Also get the timing right. Running standed ecu and intercooler. Don't get fuel cut in any gear apart from 5th and that is only of doing 100 to 125 kms after that fine. For any more details goto http://www.mrdperformance.biz/ they to all the work on my car
    • @Kinkstaah yeah I initially checked with Chequered as I've used them with a previous car. But they have stopped sourcing and installing Nistune chips. They only do tuning now. I did not want to pull out my ECU and send it away somewhere to have the chip installed. That would mean no driving the Skyline
    • Should have checked that.  On the plus side, I got my Bluetooth adaptor.
    • Each province differs a bit but we only do mandatory vehicle inspections here for heavy vehicles (Think Ford F350 and up). Those inspections are done by mechanics that are approved by the government. Besides that, it's a free for all as long as the car looks stock.  I asked because I love seeing how engineering differs from country to country. Here in Canada, all designs must be stamped and signed before they can be brought to fruition. (I.E Bridges, structures, Electrical panels, machines, literally everything shy of a wooden table) This can only be done by a professional engineer or professional engineering technologist. Both are protected titles, but the latter having more of a limited scope in what they can stamp. To become a professional engineer, you must complete a 4-5 year bachelors degree in your field of engineering, be part of an engineering order and undergo 4 years of apprenticeship, testing and mandatory continues education. Same story for engineering technologists, but a 3 year associates degree in some form of engineering technology will suffice. If you do not comply, or pretend you're an engineer or technologist, off to jail you go. If you stamp a design that fails, off to jail you go. If you stamp a design that fails and kills someone (I.E Bridge collapse) Off to jail you go for a very long time, your family will be ridiculed on the news, neighbours will surround your home with pitch forks and your dog will disown you.  Same for specialised trades... Example Electricians must undergo 1.5 years of post high school education, 4 years of apprenticeship, testing and hold proper licences. It's for the best, but then we also wonder why we're so short on engineers and tradesmen haha. We also have professional engineers who were only school smart but have no idea how a drill works. They generally go straight into management roles out of school which is also for the best.
    • Not currently, I'm at the school where we teach people to build bridges and other fun things that involve making, or breaking things
    • I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason). Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
