  • Replies 126
On another GTR I have experienced the shuffle running gt-rs turbos. Still has stock twin turbo pipe. I might suggest changing it. But once you hit 3500-4000 its hang on.
I have a mate with -10s on his R and it shuffles its brains out. He refers to is as Darth Vader, pretty funny.
Surprisingly though, he notes that in the build stages he once had it tuned somewhere different to where it was tuned now and there was NO shuffle. He rekons the car was a lot quicker also but the dyno read lower. I think the fast/shuffle-less tune was about the 380kw mark where as Darth Vader is making the 400 mark.
That would go to say the tune has a lot to do with it, but thats about all the value I can really add :( Intake piping on that car is all stock bar a big drag cooler.
So another vote for that the tune would have a lot to do with it? I'm guessing that tune wise, it's all about trying to get the engine to swallow as much air as posible down low to stay ahead of shuffle causing density. As soon as the engine can't use the air, that air has to leave somewhere else and that usually through a stalled out turbo. Well, when I bolt these on I want to take her down to Godzilla or the likes to get that tune.
When I first bought my car MOST of the shuffle was out of it. I put on a duel entry ARC cooler (and lost my BOV return pipe so the BOV's were blocked off) and that was an outright disaster with shuffling.
How did you get it to stop?
Got rid of the rubbish RS's. Would not go back to them if they paid me!
I didn't have it to begin with so I dont know how to get it to stop. My engine runs all the standard pipes/hoses on the hot side. Guess just with my engine package works for me. The engine swallows any compressed air.
It is just not like Piggaz's set up with a 2.8l which wasn't working and why he removed the HKS GT-RS and complaining that they are 'shit' but doesn't think that his engine is 'shit'.
I know it works for someone on a 2.6l. no shuffle whatsoever. ME! lol. :P
Edited by destrukshn
All done on a 2.6l @ 24psi. Actuator was leaking at the time and couldnt hold the boost. Have since upgraded to 21psi actuators and have hit 400awkw @ 5000rpm @ 28psi on the same dyno then I had coilpack issues causing misfiring/gearbox was rattling. All these have been sorted and since then I havent had a chance to get it tested, but will be testing again once it goes RB30. :)
I like.
However, my goal is to just break the 400hp mark ;) That there is like 680hp or something!!!
Lots of -7 kits floating around..... -9's very rare, probably because people either don't buy them because they're more expensive than the other GT2860's or...because people don't sell them because they like them lol :P
What are you comparing? My point is just being with any right setup you shouldnt be getting any compressor surge. If you have the setup incorrect, then you may expect some.
I am just pointing out even with -10/GTRS i am not getting any surge. Doesnt matter how much power i am making.
Easy now peoples...I was just asking about shuffle at the stage....surge as we know is a lot more violent and the turbos I was looking at are too small and inefficient to cause this. Well I think they would be anyway :)
...except for a maybe a set of hybrid 2530's that I was looking at with enlarged compressor wheels
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
