Well, I've observed the bov's doing this myself...not exactly sure how much they influence shuffle down low...they do open down low so they would take some of the air away from the turbos (sucking it back thru the recirc pipe and stealing it before it its the compressor....but after running thru afm offcourse)
The reason why the stock intake piping reduces shuffle is because it generates so much drag inside it's piping (corrugations in the rubber piping, afm mesh etc etc) that it effectively throttles the turbos by just enough to stop them getting too far ahead of themselves which would cause shuffle (too much air for engine to ingest etc)
You wouldn't happen to have posted a dyno graph in that turbo/dyno results thread? Really keen to see some of these....have been looking at GT-SS plots as thet're very similar turbos.
  • Replies 126
Lol I suppose you mean me on that one.
http://www.skylinesaustralia.com/forums/topic/378971-the-build-of-the-beast/page__st__20
Ps: I have the stock plumbing on mine. I have that hard pipe kit but need new silicone joiners. The ones that came with it are shit and I cracked the shits when installing it haha.
I have one or two -9 dyno graphs posted around the forum haha I run std intake piping but have the "twin turbo pipe" mod as I was having slight shuffle on light throttle applications when I was running 22psi with 335awkw on std engine, now I have none on current tune on 18psi 330awkw(now built engine)
Im pretty interested in this topic also. have read just about every thread about it speculating, some saying this and some saying that, its all piping, its all tune, its all turbos etc etc.
Im really interested after seeing some youtube videos: type 'Gtr surging' i think for a dyno and the noise is severe! its sounds like a high pitch screetching meets external waste gate noise. that guy had it labelled as surging, i believe it was a guy from Gtroc but not 100%.
I run -7s i believe on my 32 all with stock intake piping, apexi pods and stock twin turbo pipe with no mod (have considered it). i get the choo choo choo choo *trailing off as i believe all bov pressure is released??? when going up a hill under load and releasing the gas a fraction, i can get it to do it if i work at it on flat but most prominent on hills etc. have talked with a mate and apparently thats not a problem its only a problem if you get it all the time, basically if your not trying to do it and get it *problem.
Have since bought a cusco hot pipe which replaces intercooler pipe and twin turbo pipe back in one, these are apparently suppose to help channel air through better, waiting for tomorrow on silicon joiners then going to give it a go (just for something different). keen to see if this changes anything to do with how it drives. I also have issues with restrictions through stock dump pipes. waiting on tune in a bit to swap them out for 34gtr dumps and see if this makes it worse/lesser?
Is there anything i should be looking in to or am i fine?? is my shuffling* not really a problem, car doesnt feel bad, no vibrations or shaking. turbos are being ported and balanced with larger actuators when going for my tune for bit more hp also.
^ sure that's not just the BOV's "bouncing" off each other? Sure sounds like it :)
And don't port the turbos, they are designed to work as is. Porting will hurt response and probably not make anymore power.
I concur with ya there....that's definitely the BOV's - I can make that happen with my stockies....especially when you're driving over a long crest and you gentle let of the gas to maintain constant speed. If you're running a bit of boost you can make it go on for ages...
From all that I've read now....and what people have kindly submitted on this thread, you definitely SHOULDN'T be getting with -7's and factory intake piping, turbo-to-cooler piping and stock, plumbed in BOV's.
Ah ok, I'll will have to have a look. If I do get some shuffle I'll have to look into that TT pipe mod as well - there seem to be a couple guys on here who've nutted out some pretty good designs.
So do you think the new tune made it go away or was it the TT pipe mod?
http://www.skylinesa...st/page__st__20
Ooh a build thread nice work! Yep agree with what you said in it - always more fun in a threesom ;-) You still happy with your -9's? I'm assuming they leed a shuffle-free life??
I think a little of both, it wasnt massive amounts of shuffling but enough for me to notice, annoy me and yea I'm a perfectionist :P but all good now
I had a member on here ,craved is his username did mine very happy with his work
That's the way, so I take it that it got rid of it completely? I'll be sure to be back on here in a flash if I get some suffle ;-)
Those are some pretty impressive figures too! Is she still a 2.6? Just wondering tho - how would you compare the response of the -9's to the standard ceramic terbs? Mine are in the post now and am hoping that they're not going to be too big for around town driving...
Yea still a 2.6
Response is nearly as good as stock but don't fall over in the upper rev range
You will have no trouble around town with -9s
But ultimately it will come down to the tune and boost level, make sure if you don't already have them to get some adjustable cam gears
Ah that's the way peoples....looks like the -9's are the turbo of choice for a mildly modified GTR hoping to break the 400hp mark. Yeh it's the falling over in the top end that makes the car perform so pitifully once you're past 1st and 2nd :no:
I'll be putting these in with a set of cam gears and injectors (already have computer, pump and coil packs along with zhorst etc...so all the basics)
As for the TT pipe mod, I'll see how I go first and then go from there as a lot of people have said on here that there shouldn't be shuffle with these. Some say there will be some but they're also running much better/higher-flowing intake plumbing / hard pipe setups (i think...from memory). I'll be running all stock plumbing for now so see what happens.
Will have to enter my results into the turbo upgrade thread on here ;-)
Leviboy, you wouldn't happen to recall by how much you changed your intake/exhaust cams by with the gears??
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
