Hey all selling my '89 R32.
Needs a bit of work for roadworthy, got a checklist done today and is as follows
I am selling as is with no REGO or RWC FOR $6,000 FIRM.
Needs new master cylinder as its leaking, was quoted $120 from NIZZPRO PERFORMANCE
left hand rear door wont open
blow off valve open to atmosphere
wiper blades, and the washers are inoperative
rear wiper missing
no battery hold down
left hand inner tail light bulb needs replacement
NEEDS MOD PLATES FOR RB25 ENGINE CONVERSION AND MANUAL GEARBOX CONVERSION.
WAS QUOTED $400 FOR PAIR.
SO BEFORE READING, PLEASE NOTE THAT IS WHATS WRONG WITH THE CAR, THE ENGINE IS A1 IMMACULATE, WITH 120 THOU K'S, AND 227KS ON RUNNING GEAR, now to the upsides
has adjustable coilovers all around, RB25DET, 5 SPEED MANUAL, brass button sports clutch, 2 1/2" straight through pipe, has a nice tone, blitz blow off valve, rims.
Paint job is fading, and upholstery on the inside is teared, needs retrimming, has A/C (needs regassing), power steering, power windows.
NO PHOTOS AS OF YET. PLEASE TEXT OR CALL ON 0420860732
https://www.sau.com.au/forums/topic/398448-89-r32-skyline-gtst-6k-gold-coast/
  • 1 month later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
