Dont know if anyone else has had this problem but when im pulling tight turns at low speeds (like 10km or slower) the wheels are chattering as-if the 4wd button is engaged (though not as extreme as fully locked center diff) im pretty sure its the attessa being partially engaged.. The fluid is topped up by the way, and 4WD system works when its supposed to..
Any ideas?
https://www.sau.com.au/forums/topic/398449-c34-wheel-chatter-when-parking/
when you say the wheels are chattering, do you mean
- the wheels are skipping or chirping on the road (like a locked diff would) or
- you can hear / feel a clicking/clunking sound that gets louder the further you turn from centre ?
I would guess your front CV joint/s are the issue at this point. The only reason you notice it at low speed is because thats when you turn alot sharper than at high speed.
Jack up the front end and have a good look at the front driveshafts to the wheels, Check the CV Boot (the rubber cover protecting the CV Joint) on the inner and outer of both shafts. If the boots are cracked or split, you know grime and water goes in, and grease comes out. Eventually chewing out the CV joint.
If the attessa kicks in, you will notice it instantly on your torque split gauge. do you have one of them ?
not chattering like a lock diff, you can just feel it through the sterring but no sound coming from the tires..
Jezboosted, I think you might be onto something in suggesting the front cv's, The previous owner had replaced the boots before i bought the car so that would explain it.. ill jack it up on the weekend and inspect.. probably not worth replacing them unless they get noisey..
And no the snow button / center lock is definately disengaged,
If your car is very low, the CV boots will keep splitting as the angle of the CV gets pretty high. At high angles, the CV boot is obviously compressed one side, stretched on the other. As the wheel rotates, the rubber is constantly getting compressed and stretched fatiguing it.
I actually had a clunky CV joint aswell and i could feel it in the steering wheel at low speeds cornering sharp. I cleaned it as best as i could while being on the car, span the wheel slowly and dripped "roil" onto it. Packed it full of grease and the problem went away the next day. I have put Roil into every oil containing orifice in the stagea. That shit is liquid awesomeness. Now i am not saying it will fix your issue, but it solved mine. That was 2 years ago, problem never returned.
Edited by Jezboosted
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
