  • 1 year later...
ok not sure if nobody actually has feedback but just got this month's newsletter and one thing:
there is no point of contact (or did i miss it?) mentioned in the email? "let us know" and "feel free to contact us" has no meaning if we have no idea WHO to contact! of course, correct me if i'm wrong.
secondly i saw that you had social network submitter, i would be interested to help out with that since i'm at a pc and fairly able to post on twitter/fb most of the time.
Hmmm 13 "spam complaints" from the newsletter... Seems people do not realise there is an "unsubscribe" at the bottom.
Please don't mark them as spam, unsubscribe! :/
Gotta be careful with that one Ash or the Newsletter will get shutdown! I had the same issue when i initially did our work one and had to manually go and delete every bad address one by one! Took me over a week to sort it out!
The Spam Complaints go to an online body and they can cause you some grief!
Nah it can't be used in that fashion as we are not emailing from SAU servers, we are using Mandrill.
So it will simply not send it to them next time and over time it'll refine down, no major issue other than people just being lazy... Or someone still upset over getting a warning or something :)
Plus it works on averages IIRC, 65,000 emails / 13 "spam" - won't alter our rating in the slightest with Mandrill :thumbsup:
Hey guys,
Thanks for the feedback, will definitely add contact details in future. Funnily, we sent *so* many tests to a select few people and we changed and tweaked and adjusted and there were still things we forgot! haha.
Live and learn. :D
  • PranK unpinned this topic
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
