Hey all,
So i have an r34 gtt.
Z32 AFM, Xspurts 725cc injectors, bosch o44 fuel pump, Nistune.
Turbo, cooler, exhaust bla bla bla.
Problem is cold start is shit, idle is a little rough, and one the cars warms up, it has quite a nasty stumble low in the revs under slight load.
Everything else is great, just gets annoying when cruising around.
AFM is good, no vacuum leaks, no apparent leaks.
Ive had it retuend multiple times, and cant seem to shake it...
Im thinking injectors, but i wanna know what others may think before i rip them out and replace them,
All my parts are less than 12 months old, and its driving me nuts.
Any help would be awsome.
Cheers, Cam
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/
the stumble at low revs as you put it sounds like it could be coilpack related. but where have you been taking the car? coz the issues sound tune related to me.
or maybe fuel pump is on the way out
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6327780
going fast and stopping fast are too different things
and i don't drive that fast like i used to either... remember all eyes are on Steve when I'm out and about
Dan - the R34 wouldn't have an igniter they are built into the coil packs since S2 RB25
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328200
Its the ilde air control on the back of the manifold is carbon caked that controls idle air and cold start driveability
backside of throttle plate is most likely as well , check the TPS its a touchy bastard with nistune and voltages ever so slight can make it run wonky
Also check O2 sensor
And run a ground wire from coil packs to firewall
with cover off turn off the lights and run the engine you can sometimes see the culprit spark jumper
My splitfires played up after 2 years doing the miss fire and abs, slip, tcs warning to come on The dash
Confirm no boost leaks or vacuum leaks as well
Fuel regulator if its tee'd off for boost gauge , dont do that return to factory setup it can surge and fry a motor if it pops off
And of course fuel filter
And fuel brewed last week is different mix then this weeks cold weather batch if you didnt know that ??
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328230
Does it have nismo thermostat low temp? That on nistune causes issues until its hot as hell too
the laptop kept saying low temp on mine while on
Dyno 35c day , no issues on cold day so far just smells rich as hell for the first 2 km
My car only had 74,000km and it was caked with crap , injector cleaner wont fix that idle air problem either the injection happens below that
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328235
Cheers Steve - Lesson learned..... :domokun:
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328243
My mate had similar issues with his WRX and it turned out to be the o2 sensor or talk to Morrie at Horse Power in a Box that guy is a legend other wise i agree with everything stated in the post above.
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328726
Ashley at classic chassis and dyno in hackam , he has a Gtt so he knows them well
Nice guys who go above and beyond to do it right not time clock watchers who punch out at 4:30 like a few ive run across
But im pretty sure you will find the problem as above
Unless your wiring harness is knackered , nissan is bad for that in out vintage of cars in this climate
If the car is throwing codes even that can be a goose chase of intertwined ecu functions and not cut and dry fix.
No codes thrown , my money is on idle control and throttleplate ( unless it has greddy manafold)
The 34 O2 can be swapped with some wiring hack for another model , mine was shagged ,2 in 4 years , the r31 i just sand it back slap it in its lasted since car was new in 89 still the original one Still going strong
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6328789
Hey mate, i need u on speed dial ha ha ha.
Ok so i already checked the IAC valve, cleaned and replaced a while ago chasing this, and didnt work.
Im more inclined to the TPS, but i thought that would be show any issues while tuning, and my tuner would clearly see it? i may be wrong...
Either way does anyone here know how to check the TPS on my car?
O2 sensor is good.
No sparks in the dark, and i ran an extra earth lead from my coils when i installed them.
Ive checked leakes with break cleaner, are there any better ways?
My FPR is TEE'd off for my Profec B...
New fuel filter last week with its service.
N yeh i know fuel changes, but nothing we can do bout that, much like the price HAHA!
I might take it to see Ashley, if he has a 34, id hope he will be able to help.
Thanks everyone for all your input, keep it comin!!
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6329327
Something a bit left field, have you checked your Crank Angle Sensor? Mine was stuffed and was very difficult to diagnose, read more here.
Good luck!
Edited by V28VX37
https://www.sau.com.au/forums/topic/398460-r34-gtt-issues/#findComment-6329475
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
