Hey Kouki_S14a,
Rather than start another thread (Not meaning to hijack the thread but its the same topic i guess), can you change my rims to satin black on the 34 so i can make the final call?
I cant upload the high res files as they are too big, but its more a general look to see what it would be like, its either black or gunmetal grey but the new plazmaman cooler is satin black and so is the whole engine bay so trying to keep the theme going ;)
Cheers
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
